Question about KitchenAid KUDR01TJ Dishwasher
No power dishwasher stop working in middle of cycle. water still in the bottom no power,lights nothing .there is power coming from panel
  • bhuppa Jun 06, 2008
    no light on and water in the machine at the bottom what do I do to fix it
    President:
  • KitchenAid Master
  • 2,651 Answers
Check the thermal fuse located on electronic control 2 inch square fuse problalby no continuity through it, Replacemant comes with wires attached and instructions for installation
Posted on Feb 23, 2008
Wash cycle stopped with water in the bottom. Seems like there is no power. Can't get lights on cycles buttons to turn on. Power button does nothing. Checked circuit breakers. All are on. Lights and outlets...
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Jan 14, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
Jan 29, 2008 | Asko 24 in. D3120 Dishwasher
No lights on, didnt complete the drain cycle, stopped working now
There is a thermal fuse located in the control panel inside the door. It could be blown, but if so what caused it. they come with a retrofit pigtail to prevent loose connectins on the fuse. You may have a short somewhere in the dryer, and just blow the fuse again. Could be bad motor,fill valve, or heater, or even the control board. I'd try one fuse first.
Jul 26, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
My whirlpool dishwasher just stopped working the middle of the cycle with water still in the bottom and now nothing lights up or comes on and the water is just sitting in the bottom. Any suggestions?
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault and required to be replaced. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 04, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
THE DISHWASHER STOPPED WORKING. NOTHING COMES ON.
call for a technician to do the checking of the problem maybe it needs repair
Nov 17, 2009 | Dishwashers
Problems with Whirlpool dishwasher model GU1500XTKB0
have they checked the thernals on the bottom of the tub
Mar 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
KitchenAid KUDR01TJ Dishwasher Logo
345 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
