Question about Samsung RS2630SH Side by Side Refrigerator
My samsung da9901278c ice dispenser got stuck how do i fix it
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
How do I Prevent ice dispenser from freezing up? Ice is in the ice bucket but will not disperse.
The ice stays in the cubemaker tray for a set time and then empties into the bucket. If the freezer was too warm the ice wasn't frozen enough when the cube maker emptied it and it all stuck together. Now the fridge is cold again empty the bucket, make sure there is no ice stuck in the dispenser and try again. If it is a Samsung fridge do the above and turn it off for 30 seconds and back on again. Sometimes the controller and display freezes and reads the wrong temperature.
Nov 18, 2014 | Refrigerators
Freezer thermastat is stuck and ice dispenser clogged, how to fix the problem
Check rear of the freezer for frost , If you have frost there you will need to service the defrost circuitry. More times than not the defrost heaters are the problem
Aug 02, 2014 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
Samsung rs22dcms not dispensing ice (ice is made)
My guess is that the doo switch is faulty or stuck open so the relay never closes to power the auger. I would check the door switch first then the auger motor.
Sep 06, 2012 | Samsung Refrigerators
Ice dispenser is stuck in crush mode
the solinoid is most likely stuck down. however most of the time there is more ice in there than you realize
Feb 05, 2010 | Refrigerators
Samsung RS21DCNS: Ice maker fills up but water dispenser does not dispense water
the fridge is making a noise , sounds like a fan catching and the water will not flow
the firdge is a Samsung RS21DCNS 19.6CF
Oct 04, 2008 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
46 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
