Question about Philips 60PP9352 60" Rear Projection Television
Red, green and blue bulds are working but its not putting the red into the screen whats the problem..
  • Philips Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonicred, green and blue bulds are working but its not - 2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 22, 2010
  • willmon22 Apr 27, 2011
    Well the convergence is fine. The problem is the color is completely out of alignment. Also the power button is orange or red and never turns green I forget what it means but it is like that. Isn't there some way of getting the knobs to their default settings with turning them all down and turning them a certain amount of turning? I could really use some help with this as I can't get it to look the proper color. I will take a picture of it and upload the picture to photobucket and put it here to show you what it looks like when I get the chance.
SOURCE:
After lamp replacement, why is picture still green?
it seems like the green was not defective before you replaced the green. remove the red =no change in the screen color, that could be bad. put back red, then remove blue=screen color changed, blue is good, hope you got the idea.
Oct 08, 2015 | Sony Televison & Video
My screen is showing green but my buld is still good. It all green and has hint of blue at the edges. What could be causing that issue?
The LCD panels of your projector are starting to fail. Unfortunately you'll need to have the whole LCD block replaced.
Jun 08, 2015 | Panasonic PT-AX200 LCD Projector
My screen is green i was going to change monters didn't work so i put it back and it turn green.help please.
Red, Green, and Blue are the colors sent from your computer to the monitor. Sounds like red and blue are not working. If you've tried a new monitor, I'd try a new video cable next. Then clean the connector on the back of the computer (compressed air). Finally, replace either the video card or the computer.
Oct 04, 2010 | Computers & Internet
What kind of bulb do i need for this model of tv
sorry but this tv is a rear projection tv , dont use buld , use 3 picture tube which are blue ,green ,and red
Apr 19, 2010 | Sony KP-43HT20 43" Rear Projection...
I have a Television with red, white and yellow connections. The wii console has red blue and green. What wires go where??
Red= Video- Put the red to the red
Green= AV3- Put the yellow to the green
Blue= Sound- Put the blue to the white
Dec 31, 2009 | Nintendo Wii Console
Tv works but has red glare on screen
You have contamiated fluild in red tube remove old projection fluild and put in New this should then give you a clear picture. call Mats for projection fluild 1-800-628-1118
Sep 18, 2009 | Televison & Video
Top ds lite screen is red green and blue
The same thing happened to me, You might want to replace your ds touch screen...
Feb 05, 2009 | Nintendo DS Lite Console
RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEAR ON THE SCREEN...
Remove battery , let sit for 2 miniutes . Re install battery , in proper position , hold on button for a few seconds and this should work ...
Jun 11, 2017 | HTC TYTN GSM Phone
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
May 07, 2008 | Philips 43PP9202 43" Rear Projection...
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
Philips 60PP9352 60" Rear Projection Television Logo
909 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
