Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Whirlpool duet gives me an error code of F 02
Whirlpool duet gives me an error code of F 02 What's the problem
  • 5,911 Answers
"F02" is a Long Drain error code. This is an indication that there's an obstruction in the drainage system somewhere. Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the lower toe panel directly below the door in the FRONT of the washer. They are located under the bottom front edge of the panel. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Posted on Feb 05, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Tip
    WHIRLPOOL Duet & Duet HT washing machine shows F/02 error code on display?
    This error is shown on the display due to:--
    Drain time exceeding more then 8 minutes, the water valves will stop functioning and the the water valves turns off and "F/02" will be displayed on the screen.
    NOTE: in some cases it has been noticed that 4 minutes the "Suds" error displays, and then 4 minutes later the F02 error displays.
    This Will Help.Good Luck.
    on Mar 11, 2010 | Washing Machines
    Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
    Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
    Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
    With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
    With the filter out clean and install it back into washer.
    Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
    If you require a new drain pump motor, you can purchase the part from the link below.
    - See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
    Sep 06, 2014 | Whirlpool Washing Machines
    Whirlpool duet washer error code f-02
    Error F-02 is a slow drain problem. Remove lower front panel. You will see a circular door. Be prepared for a lot of water and junk, maybe keep some old towels ready. Open, clean out, check pump which comes right behind it - see that blades rotate freely; refit carefully. You are done, for the next six months or so, depending on usage.
    Click if helped
    Apr 14, 2013 | Whirlpool Washing Machines
    F- code 02
    How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
    With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
    Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
    Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    F-02 error code on whirlpool front loader duet
    http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
    May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    F/02 Long Drain
    If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
    NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
    Press PAUSE/CANCEL twice to clear the display.
    • Check the drain hose and make sure it is not plugged or kinked.
    • Check the electrical connections at the pump and make sure the pump is running.
    • Check the drain pump filter for foreign objects.
    • If the above does not correct the problem, replace the pump
    Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    F 02 Error code, took apart and found 2 small
    WHAT DID YOU TAKE APART AND FIND THE NAILS? WAS IT THE PUMP? SOME MORE NAILS MIGHT HAVE GOTTEN BACK IN THE PUMP OR THE PUMP IS DAMAGED.
    Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    I get the error code S02 on my Duet washer. It
    02 is a slow drain,
    yopu can check your pump
    take off the back wall and hoses,, have towels ready
    you will loose water,,
    inspect the inside of the pump and all hoses
    Oct 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
    108 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
