Question about Epson Stylus C88 InkJet Photo Printer
Epson C88 shows red alternately blinking lights
After printing a nozzle check, the ink and paper lights blink alternately red, and the green power light is not on.
Using the printer for sublimation
Can't get past this, help!
    Sergeant:
  • 420 Answers
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
Posted on Sep 18, 2010
I put in new ink cartridges and now there is an E and 2 red blinking lights
Which lights are blinking red? What is the rate of the flashes? I'll assume that one of the blinking lights is the power light (just means error).
If the either of the ink cartridge lights is blinking rapidly, the cartridge may not be seated correctly. Try reseating the cartridges and then press OK to clear the error. If it is a less rapid flash it could be that the print head isn't reading the cartridge ink level correctly. Please note: refilled or non-Epson cartridges may not be read correctly due to information stored in a chip on the cartridge or in the printer.
In this case the problem may be in the print head and Epson doesn't recommend cleaning this yourself. You can replace it. (On other inkjets, pop out the cartridges, remove the print head and wipe with soft, lint-free cloths or q-tips dampened with bottled or distilled water (wring out excess water). On each section, you wipe away from the nozzles. Then wipe off the inside of the print head carriage (contacts) as well. Dry everything with a dry cloth and reassemble the printer.)
If the Check paper light is blinking check for a paper jam or the printer looking for a different paper size.
I hope this helps.
Oct 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Connected r1800 to mac, print browser page, blinking power light, no printing
Run a nozzle check to see if all inks are printing out. Turn printer off, then hold down the paper button ( top ), while holding it down, press and hold the power button. When you see the power light flashing green, release both buttons. It should print a nozzle check pattern. You should see 7 columns of different colored lines and one checkered board pattern. There should be no gaps and breaks on the lines. If pattern is no good, you need to do head cleaning.Press the ink button for 3 seconds. Power light will flash and print head will move. This will take one to two minutes. After it is complete ( power light turns solid green ) you need to do a nozzle check pattern to verify if there is improvement or If head cleaning needs to be repeated.
Apr 11, 2010 | Epson Stylus Photo R1800 InkJet Printer
Red paper and ink lights blinking
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
Mar 19, 2010 | Epson Stylus 1400 InkJet Photo Printer
Epson r230 general error
Blink alternately or not? If alternately, the message is not "general error". but "service required" It's true to reset waste ink counter. But, i think it's not service required. when trun on printer ready? But when start to print red lights blink at same time? Problem with chip at ink tank. Check connector at chip and at head carriage. It's may be dirty, and not good connection. try to use another chip.
Jun 22, 2009 | Epson Stylus C86 InkJet Printer
Epson R1800 paper and ink lights are blinking
See status monitor? Is service required? Reset waste ink, Find resetter at indoreset.blogspot.com
Jun 09, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson CX7450 paper jammed
In some cases, this is cause by a nozzle that got clogged during the jam. You can run head cleaning utility either from the printer or from the computer.
1. Make sure that there are no error lights (red lights), just a solid green light.
2. Take out all cartridges from the printer and put them back in.
3. Once the printer is done charging the inks and you have a solid green light again. Hold down the Ink Button for 3 seconds, after this you'll hear movements within the printer, this is the head cleaning process.
4. Once the printer stops making noises, and you have a solid green light again. Power Off the printer
5. Once the unit is OFF, hold down the paper button while turning the printer ON. Once you see the blinking green light release BOTH buttons. The printer will then print the nozzle check pattern.
* Note: The nozzle check pattern should display all colors in the printer and there should be no gap or break between the lines itself.
6. Do this step 3-4 consecutive times. and that should resolve you concern
Feb 21, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Printer will not print
Which of the two red lights is on? If it's the red paper light, it simply thinks it's out of paper. Make sure your stack of paper is properly seated in the Automatic Sheet Feeder. If it is the red ink light, it means that during a print task (printing, head cleaning, ink charging), an empty cartridge was detected. Go through the cartridge replacement procedure as described in your User Manual. If you don't have one, see:
http://files.support.epson.com/htmldocs/sc88__/sc88__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
"Replacing an Ink Cartridge.
If this information doesn't answer your question, please post a new comment with more information on what you want.
If this information was a help, please rate it.
Jan 25, 2009 | Epson Stylus C88 InkJet Photo Printer
C88 Printer won't print
Just as a follow up to this one for anyone else who hits this problem...
You can service the printer and redirect the waste ink yourself using the guide and information provided from this guide which I wrote a couple of years back.
It applies equally to the C84 - C88 and D88 models and certainly requires a certain amount of technical skill and patience but not beyond the amateur with a LOT of patience :)
In terms of resetting the waste ink counter or "protection counter" which triggers the service required message you can't use the SSC utility but instead will need to source the official adjustment utility.
Getting the product serviced is an option but frankly it usually costs more than the printer was worth so you've nothing to lose by trying to fix it yourself.
Hope that helps
Oct 01, 2008 | Epson Stylus C88 InkJet Photo Printer
EPSON R230 PRINTER
ONCE PRINTE COMMAND IS GIVEN PAPER IS ROLLED IN AND THEN PAPER JAM RED LIGHT BLINKS. CAN NOT PRINT ANYTHING.BUT NOZZLE CHECK PRINT CAN BE PRINTED.
Jul 23, 2008 | Epson Stylus Photo R200 InkJet Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
Epson Stylus C88 InkJet Photo Printer Logo
781 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
