Question about Harman Kardon HK695 Computer Speakers
Aerius , martin logan speaker fuse blown 0,25 amps where can i get one thanks
How do I brigde a krell show case amp from 5 channels to three channels
Thai will require removal of the top cover to move jumpers or program dip switches in proper order. This will be explained in the owners manual which is located at Krells web site.
Steven Leckrone
The Service Department
30 Unquowa Hill St
Bridgeport CT 06604
203-331-0671
Steven@theservicedepartmentct.com
www.theservicedepartmentct.com
Nov 14, 2014 | Krell Audio Players & Recorders
How can i connect my dynamo 700 w using martin and logan transmitter to my marantz sr5008
You just need one of these though all the sockets would need to be male:
Jul 06, 2014 | Audio Players & Recorders
I have a Technics SA - DX750 Amp Everytime I turn it on I get an error message F70 and then it requests that I turn the power off. This is all it does now, so sound. How do I solve this issue I have...
Hi!
The F70 error certainly indicates a blown fuse inside.
The real problem is why the fuse is blown: there are only two possible reasons
1. there is a short circuit on the output (lines or speakers)
2. you have a blown output transistor (and that means some work and skills to replace).
To be sure, please change the fuse with a same rated fuse (buy more than one because it can blow again). Disconnect the speakers and turn the amp on. If the fuse blows again, it is sure something wrong with the output transistors. If the fuse remains ok, then please check all the wiring to the speakers.
Hope it helped.
Regards,
Bogdan
Aug 21, 2011 | Technics SA-DX950 Receiver
I have the 1911 and Martin Logan Motion 10 speakers. Why do I have to turn the volume up so hi to get sound?
are the ohms on the speakers and the receiver rated the same, if not theres the problem
Mar 14, 2011 | Denon Audio Players & Recorders
Bose radio comes on but no sound in my 2004 chevy avalanche.Sometimes even with radio off you hear a popping sound come from speakers. thanks
First Visually check all your fuses. Does rig have amp for stereo by any chance? It sounds like amp is bad and/or fuse is blown. Amp is wired between radio and speakers, and a shorted amp would make crackling in speakers when radio is OFF
Feb 26, 2011 | 2004 Chevrolet Avalanche
I own a used Martin Logan Dynamo (older series) and just today found out there is no sound coming out/no led light (at the back) either. I opened up the back and saw the 110V power is getting in but no...
Did you get the sub fixed? I know someone with the same problem - won't turn on, fuse is fine. May be due to different underlying problem, but wondered if you discovered what it was and if you got it fixed.
Mike
Aug 28, 2010 | Dynamo MartinLogan Subwoofer Speaker
McIntosh 6100 Integrated vintage 1976
Most likely, one channel is blown plus power supply capacitors have to be replaced, switches and controls cleaning, all lamps replaced. That would be an average repair on that model.
Nov 11, 2009 | Mcintosh Audio Players & Recorders
Marathon 2000 amp... PROT light
Ok this means the AMP is in protection mode!..most likely the cause is a short in your wireing from the speaker wires! check all wires going in and out of amp! Look for stray wires touching metal or other contacts! (If this does not fix it the short may be inside of amp!
(This has nothing to do with a fuse!)
Please rate this FREE response!
THANK YOU!
Jan 19, 2009 | Marathon DJ-2000 Amplifier
BLOWN FUSE?
If no warranty - remove amp and check sub to another amp to isolate speaker from internal amp. Either the amp blew a channel or subwoofer blew. JBL's are typically well built. Has this speaker often been pushed loud often?
Apr 23, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Harman Kardon HK695 Computer Speakers Logo
121 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
