Question about Refrigerators
Freezer is frosting up and will not stop running
Hotpoint refrigerator - HSM25GTASA freezer is frosting up and will not stop running
    Sergeant:
    Champion:
  • 263 Answers
Most likely your defrost heater and/or defrost thermostat went out.
Hotpoint refrigerator repair in Orange County, CA
Posted on Feb 05, 2010
Hotpoint fridge freezer ffa60 frost free bottom freezer has stopped working top fridge is ok 6 years old help!
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | Hotpoint HSS25GFP Side by Side...
Refrigerator freezer not cold
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Is there anything else that makes you think this is a problem.
Sep 11, 2009 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Hotpoint frig,top freezer motor runs contiunally, thermostat set in middle of temp. control. side of frig stays cool all time.[does not get warm as it used to] is defrost thermostat bad or timer?
niether. is there frost on back wall of freezer? if no look behind back wall and see if there is frost on all the coils when running. if less than 80% is frosty...freon. or is there frost covering back panel..if so then defrost problem would be correct. but side would be warm so I think not.
Jun 12, 2009 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
I have a Hotpoint model HSS221FMD & works when I unplug, & thaw freezer. Then after a while running, the cooling stops on the fridge side & the freezer cools a little & frosts up
This sounds like a bad thermostat. not a very expensive fix but i would call in the pro's mainly due to its location and frail parts. This should be around $100. Give or take a little. Good luck.
Jun 05, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer fan not running
Often times the defrost termination switch (which opens when it gets warm enough) will hold the fan off until it closes again when the freezer runs. It is possible that the switch is not closing, but be sure the freezer is getting cold enough for it to close.
You know the freezer is likely cold enough when you see frost covering the entire evaporator coil after a few hours of operation. A partial frost pattern could indicate low refrigerant, or a restriction of refrigerant.
May 29, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Freezer not freezing
when the freezer is not freezing, check the fan and fan motor in the freezer section. It should be running when the compressor is running. Check for frost. If you see frost on the rear inside panel, the frost is usually about 3 in. thick on the inside. Check and make sure the fan next to the compressor is running, if your's has one. It will run when the compressor is running. Check for gaps in your door gasket. If there is no frost, both fans are running, compressor is running, and no gaps, and your coils outside the refrigerator are clean, it doesn't sound good.
May 04, 2009 | GE Hotpoint Top-Freezer Refrigerator
Refrigerators Logo
103 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
