Question about Brother MFC 7420 All-In-One Laser Printer
Will not download-gets to point of connecting cable and turn on of printer-then waits 3-4 minutes and screen begins to flash slowly-won't download printer final info.
    Scholar:
  • 66 Answers
Try downloading the file on an alternate computer or laptop and burn to disc or flashdrive. Problem may be vendor related or local PC but you must isolate the problem.
Posted on Feb 05, 2010
Printer shows alarm with p and 8 flashing
Follow this instruction step by step.
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Printer won't work while auto answer light is on. cannot get it to turn off.
I would suggest you to do power cycle to the printer take out the power cable and wait for 3 minutes and then plug it back in. if the issue still persists contact us with the exact model of the printer
Jul 06, 2011 | Office Equipment & Supplies
What does it mean when the far ethernet light is flashing fast and the cable light is flashing slowly. the power light and on line light are on steady. I have internet access when connected direct to...
Try this:
  1. Disconnect power to modem
  2. Disconnect power to router
  3. Shut down PC
  4. Wait 2-3 minutes
  5. Reconnect power to modem, and wait ~ 1 minute
  6. Reconnect power to router, and wait 30-60 sec.
  7. Reboot PC
  8. Try to reconnect to internet...
Jan 15, 2018 | Arris Touchstone 450a (CM450) Modem
For the past week, when my Sceptre LCD monitor goes to sleep after inactivity, it won't restart immediately. The blue LED blinks every second or so; eventually, the screen begins to flash the display, and...
Hello there Jake.
Here's your geek-steer ...
== CLARIFICATION ==
  • When you say "sleep", are you certain it's sleep mode, as opposed to hibernate?
  • "...it won't restart immediately." ... you do mean of course AFTER you've given keyboard or mouse input, right?
  • "...the screen begins to flash the display" ... literally flash, as in strobe? Or do you just mean flash, as in "shows".
  • "...Sometimes the whole process takes five minutes, sometimes an hour." ... ???!!! If it takes anything longer than few/several moments, that's very abnormal, even if hibernate mode.
  • "...I can't find the documentation." ... not important, at least not at this point.
== SUGGESTIONS ==
A. RULE OUT THE SIMPLE FIRST.
1. Shutdown
2. Turn off PC and monitor
3. wait 5 minutes
4. unplug all cables/cords connected to monitor (both ends)
5. inspect/clean connect points
6. reconnect all cables/cords
7. plug monitor back in
8. startup system
9. try to duplicate problem
B. CPU HOG.
I'm curious to know what all your "Processes" are doing during this very delayed period of time. By knowing that, you can see which one(s) are running, and which of them are probably crunching hard at the CPU, which MAY explain the delay (I don't know about an hour, but minutes ... yes).
Do you have a "Processes" monitor utility of any kind? If not, get SysInternals' "Process Explorer" (no installation required, just unpack and launch). Make sure at least the "CPU History" item is included in the column header (View > Select Columns). Once launched, allow it to sleep.
Just as soon as able, after it comes out of sleep, review Process Explorer. What, if any, processes are hogging CPU? Post that back, and I suspect we may be a lot closer to a solution.
C. MONITOR FAILURE.
You might also hook up this monitor to a "known good" (functioning properly) PC with like "screen saver" and "power options" settings. If problem not encountered, you can at least isolate the problem to solely the monitor. However, if the only time you encounter problem with monitor is isolated to when coming out of sleep, this is likely a long-shot.
Good luck Jake, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback.
  • if you have any further questions,
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 06, 2009 | Computers & Internet
Viewsonic Projector PJ557D "Screen Flip"
Check the power settings o nthe laptop, go to control panel, power options. see if its set to turn off the screen if theres no activity. I doubt this is your problem but worth a try. Going back to the viewsonic picture means its not getting a signal. So either the cable may be faulty which is less likely, or it is a software problem. Does the screen flicker on the laptop when doing the same thing (if the projector is not connected)?
Jun 12, 2009 | ViewSonic Lenovo Viewsonic PJ557D Portable...
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
First Page printing Jibberish with the Zen thing at the end.
Try these.
Reset the Photoconductor Drum Counter
1. Turn off the power using the switch on the back of the printer.
2. Open the front door of the printer.
3. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash.
4. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
5. Wait till the printer completes the POST process.
6. Press Cancel button 4 times slowly until the Toner Low LED is lit.
7. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue.
Now only the
8. Cycle the power of the printer.
- Remove the power cable
Feb 24, 2009 | Dell 1720dn Laser Printer
Help Urgent
Hi Natasha,
If the button settings didn't help, then try resetting the printer.I have mentioned all 3 kinds of resetting, try and let me know.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the Ink Cartridges, then unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds then release the button.If the printer goes off don't worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thanks n Regards
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | HP OfficeJet 4255 All-In-One InkJet...
HPc6150 printer error
Hai
I Seems to be a hardware problem.Follow my troubleshooting steps.
STEP 1:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.(if it doesn't works goto step2)
STEP 2:
PARTIAL RESET:-Take the Ink cartridges out, Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
STEP 3:
SEMI_FULL RESET:-Take the Ink cartridges out, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
STEP 4:
If they don't work, the printer needs to be serviced.Let me know the status.
Thanks
Riz
May 31, 2008 | HP Photosmart C6180 All-In-One InkJet...
Alignment failed
Just try to reset the Printer.the pro L series printer can be reseted as follows.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
FULL NVM RESET:-Turn the printer OFF, Disconnect the power cable from printer and from the wall outlet.Wait for 1 minute.Connect one end of the power cable to wall outlet.Press and hold # and 9 button and connect the Power cord while holding.After connecting , release the button.Then Turn ON the Printer.
Feb 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Brother MFC 7420 All-In-One Laser Printer Logo
51 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
