Question about Shinco DVD-833 DVD Player
The dvd will not turn the dvd - Shinco DVD-833 DVD Player
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
HOW TO EJECT DVD THAT THE PLAYER WILL NOT READ
turn the unit on, set to dvd and turn off. then press the dvd open/close button, it should turn on and open without reading the disc.
Mar 22, 2010 | GoVideo Go Video DVD/VCR Combo
Wont turn off
Acually there is a setting by which you can activate " Auto Power Off" in your DVD player. You can make that setting and it will be automatically off after DVD finishes.
May 13, 2009 | TruTech TT320
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
Reset dvd to
Turn down the power . then turn back on and hold the stop button for 20 sec. this should reset the player
May 26, 2008 | Cyberhome CH-DVD 300 DVD Player
Vizualogic dvd A1000 dvd doesn't work
Ours does this as well sometimes usually if you turn the dvd off turn the car off then turn car back on then dvd player it comes back on
Apr 30, 2008 | TMI Products Vizualogic Headrest Pair...
Trouble Loading & Not Registering To TV
I can't say 100% but it sounds similar to the problem I had with the same model . The sleep mode in the on/off switch had gone bad and a new switch fixed the problem. It was about $42 to rtepair at my local electronics repair shop. Hope this helps.
Jan 30, 2008 | Yamakawa DVD-218 DVD Player
Magnavox dvd player turns off
try turning the dvd player off and leaving it unplugged for 5 to 10 minutes then plugging it back up
Dec 28, 2007 | Philips Magnavox DVD/VCR Dual Player
Shinco DVD-833 DVD Player Logo
Top Shinco Televison & Video Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Shinco Televison and Video Expert? Answer questions, earn points and help others
