Question about SanDisk Sansa e250 MP3 Player
Shutdown problem when i switch on my player it shows 'battery is too low system shut down' after charging it shows the same problem, what can i do....?
  • 4 Answers
How long have you had this item? Did this situation happen over time or just suddenly? Does it happen as soon as you turn on after charging or does it take a short while? If this has happened after owning and using for a while, I would suspect that the battery is worn, or just not holding a charge for whatever reason (not important). The fix for this problem would be to find out of battery is replaceable and then to get a new battery if it is. Also, don't buy a used battery as this problem will just happen again sooner than it will with a new one. I've owned many music/video players and some batteries are just duds from the get-go and don't last anywhere near what they should! Hope this helps! ;)-~ If the battery isn't replaceable then you'll just have to spring for a new player.
Opinion #2 Check and see if manufacturer website offers a firmware update for your product, sometimes this can fix certain problems as I had a battery problem for a digital item that was fixed this way, but my item was new and I was sure that it wasn't an old battery problem.
Posted on Feb 05, 2010
Liebert gxt2-10000t230 low batt,bypass light flashing,no output,shutdown after a minute
Test outlet power by switching the unit to manual bypass and breakers off.
If power is supplied OK and the filter board repaired OK then restart the unit starting with the breakers supply to unit,battery confirm the display is on and static bypass led also on then switch back the bypass knob to normal and press the on button to switch the unit to normal.
Give the batteries time to charge 12hours then you can test the unit on backup mode.
Nov 25, 2014 | Liebert (GXT2-10000T230) (GXT2-10000T230)...
While charging it gives battery is too low system shutdown
Try charging for at least 4 hours when it is switched off.
Apr 07, 2011 | SanDisk Sansa e260 MP3 Player
Showing a LP on display. What are the possible problems?
Here is the reason for that problem per the manufaturers web-site
http://www.haywardnet.com/products/Manuals/pdfs/Manual122.pdf
The low-pressure switch senses the refrigerant pressure in the sealed refrigeration system to
protect against certain conditions that could be detrimental to compressor life. The switch shuts
the unit down in the event of loss of refrigerant, fan motor failure, evaporator freeze-up and
airflow blockage. The switch automatically resets when the pressure rises to normal operating
pressures. The display will show "LP" if this switch is tripped.
Evaporator Freezing
The low-pressure switch will shut the heat pump down when the evaporator starts to freeze.
When the unit starts to freeze the low-pressure switch will be tripped, causing the display to read
"LP" This will prevent the evaporator from becoming damaged or deformed.
If the air outside the heat pump is not warm enough to produce heat, the system will shut down.
The actual point at which your unit will shut down due to low temperature varies depending on
which model you purchased, current weather conditions, and the amount of sunlight reaching the
heat pump. The shutdown can occur anywhere within a wide range of temperatures, usually 45°F-
55°F. This is not a "fixed" range. We stress that climate conditions, sunlight, and various models
respond quite differently to low ambient temperature. A shutdown occurs because low
temperatures will activate the systems low-pressure safeguard switch (digital thermostats will
display a code "LP".) The unit will start up again when the temperature has raised enough to reset
this switch. Note: Low ambient temperature does not necessarily affect the Chiller models
or the cooling cycle of the heat/cool units.
If this post has helped you, please take the time to vote positively for me on this site. If you need additional help, I can be reached @: adamh@newconceptchem.com
thanks,
adam
Oct 23, 2010 | Hayward Heatpro 81k Btu Swimming Pool Heat...
I charge the MP3 player and it still shows "low battery" message.
There is a trick to charging the battery in these small mp3 players. It won't charge if it is turned on, and it won't charges if it's turned off. Here's what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
That is if the battery is still chargeable after all this time. The battery may well require replacing.
Apr 19, 2010 | Creative Labs ZEN V Plus MP3 Player
Unexpected shutdown with fresh battery ...only cycled 23 times so far. Mac shuts down after about 3 minutes....then shuts down on boot sequence after that. No warning...just shuts down instantly. Macbook...
"Shuts down instantly without warning" is the hallmark of a faulty battery. "All five lights on" is meaningless, as batteries with this fault go from 100% to 0% in a finger-snap. Assuming your battery is under warranty, it should be replaced at no charge.
Nov 08, 2009 | Apple MacBook Pro Notebook
Unexpected shutdown with new battery ...only
This is a duplicate submission -- I will be answering the other copy. Thanks.
Laptop doesn't work on battery after charging
If you are planning to open the notebook make sure the cpu cooler is mounted flush and has the most possible amount of contact with the cpu for heat transfer. I don't know about yours but normally in bios you can set a fatal temperature shutdown. Try to look up what cpu you have (when you open the case) and see if maybe the temperature is set too low. Then you would be able to reset the temperature to something higher if possible and this would solve the overheating shutdown problem.
Jan 02, 2009 | Computers & Internet
My YP U3 don't turn on
DONT TROW IT AWAY!!!!!!!!! push hold buton and the play/rec butons, this will reset your system, and than! tcharã! ok again!
Apr 03, 2008 | Samsung YP-U3 MP3 Player
Sansa e280
Have you tried recharging the battery? If it is not showing when you connect it to your computer, try holding down the Menu/On-Off button for 15 - 30 seconds and see if it goes on.
If you need a new battery this is a good place to get one:
http://www.jr.com/JRProductPage.process?Product=4153711
Feb 04, 2008 | SanDisk Sansa E280 MP3 Player
"Battery Is Too Low System Shutdown"
The battery has come loose from the contacts on the inside.
Remove the back (4 screws), remove the battery and put it back in securely.
Then charge it for a couple hours.
Best of Luck.
Nov 14, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
76 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
