Question about IBM ThinkPad T23 Notebook
How do I remove/replace the LCD screen - IBM ThinkPad T23 Notebook
    Sniper:
  • 91 Answers
Plz see if there is a button called Fn in your laptop..
then start pressing Fn+all the f1 to f12 keys
Posted on Feb 05, 2010
  • 136 Answers
Please go to this link below. it will help you to remove/replace lcd screen.
http://computershopper.com/laptops/howto/replace-your-laptop-screen
How to dismantle lcd of Neo Basic B3362n
A replacement screen maybe available from this WEB site.
www.lcdparts.net
The screen is removed by undoing the hinge screws, careful unclip the video connector from the motherboard.
Keep the screws together as you remove them so you will know which screws are needed to install when you fi the new LCD screen
Undo the screws that hold the bezel that surround the LCD screen, then remove the bezel (it may be also held in place with double sided tape).
When the bezel is removed the LCD screen is secured to the hinge assembly by more screws around the edge of the LCD screen.
When you install the new LCD screen, reverse the order you took in removing the LCD screen.
These WEB sites may assist you in repairing the LCD etc.
Nov 30, 2012 | Computers & Internet
Screen Replacement
Simple. Check out the youtube video. Basically all screens are about the same as far as taking them apart. There will be rubber bumpers on the plastic strip that is around the screen to remove and then the screws will be exposed. Remove the screws, remove the plastic strip by prying it off with a little force from you fingers. Then remove the screws that hold the lcd screen to the bracket. Be mindful of the cable that is behind the lcd screen that you will have to remove and be mindful of the lcd inverter at the bottom of the screen that will have a cable in it from the screen. Some later models use what is called LED instead of LCD screens and they don't have lcd inverters.
Youtube video link is below.
http://www.youtube.com/watch?v=o7vSFvHphxM
May 21, 2012 | Computers & Internet
Change sceen
www.lcdparts.net
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Laptop repair info
http://www.laptoprepair101.com/
Feb 11, 2012 | Computers & Internet
How to replace a lcd screen on a notebook
Hello
Here is the detail pictorial view of replacing screen of dv6000
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
Good Luck, and do rate the solution if got help
Dec 30, 2010 | HP Pavilion dv6000z Notebook
How to change out a broken lcd screen on an aspire
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
This is its contents without the pictures:
OK, let’s get inside the display assembly.
First of all, turn off the laptop, unplug AC adapter and remove the battery.
The screen bezel* has four screws hidden under for seals. Two rubber seals on the top of the bezel and two plastic seals on the bottom.
You can remove all four screw seals with a sharp object as it shown on the picture below. Glue removed seals somewhere on the bezel so they don’t get lost.
Remove four screws found under seals.
Start remove the screen bezel with your fingers. Proceed slowly while removing the bezel.
Carefully separate the display cover from the screen and access the LCD cable connector
You’ll have to unplug the LCD cable from the screen.
First, unglue the clear sticky tape securing the connection.
Second, unplug the LCD cable from the connector on the screen.
Here’s how you can remove the LCD screen.
Simply remove four screws securing the LCD screen to the display hinge. Remove four more screws from the other side of the screen.
Now you can remove and replace the LCD screen with a new LCD screen.
Put all the screws back in there places
Dec 31, 2009 | Acer Aspire One PC Notebook
Replace laptop screen
STEP 1.:-Turn off the laptop and remove the battery.There are no screws securing the screen bezel. Start separating the screen bezel from the display cover with your fingers.
STEP 2.:-Continue removing the screen bezel on the top.
STEP 3.:Remove bezel from the hinges.
STEP 4.The screen bezel has been removed.
STEP 5.:Remove six screws securing the LCD screen assembly.
STEP 6.:-Separate LCD screen assembly from the display cover.
STEP 7.:-Place the LCD screen assembly face down on the keyboard. Now you can access the back side of the screen and disconnect cables.
STEP 8.:-Disconnect the video cable connector from the LCD screen controller board.
STEP 9.:-Parts of the video cable could be glued to the screen. Unglue the cable.
STEP 10.:-Disconnect cable from the inverter board.
STEP 11.Remove the LCD screen assembly.If you are replacing the LCD screen you’ll have to transfer mounting brackets from the old screen to a new one.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 23, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Replacing top back cover to Lcd
In front of the screen you should see little rubber contact pieces shoild be about 4- 6 remove these and underneath are the screws to remove housing.
Inside you will see how lcd screen is attached.
Remove lcd screen then replace what you need to. This is the same for most laptops and I would just google your model # tofind out exactly how to.
May 27, 2009 | Dell Vostro 1500 Notebook
Replace LCD screen
All modern thinkpads are similar, you start by taking apart keyboard and top cover, then you unscrew hinges and remove screen. Here is some movie:
Thinkpad LCD Removal
Removing Thinkpad 600 Series Display - Part 1
Replacing Thinkpad 600 Series Display - Part 2
IBM ThinkPad R40 -- Fixing the black-out LCD Screen
This is not an easy job, there is risk to cause further damage to your laptop if you do not have enough experience.
May 28, 2008 | IBM ThinkPad T60 Notebook
Hp pavilion dv 1000 screen replacment
Dear lotaman, I have searched the world to find an exact guide for your monitor but it is impossible. Neveretheless I have found the following guides and they should be more than enough to complete the task in hand anytime.
TIP: The ZV5000 looks and is very similar to the HP DV1000 screen so I would start from there. All guides are very nicely explained.
Please remember to remove the battery before you do any work with the laptop.
Regards
Removal Step by Step HP ZV 5000 LCD Screen
http://www.instructables.com/id/SJFP10QF49G0AOR/
Removal Step by Step Compaq V2000 LCD Screen
http://www.screentekinc.com/lcd-removal-instructions_en,compaq.shtml
Removal Step by Step Compaq DELL LCD Screen
http://www.laptoprepair101.com/laptop/2007/02/03/repair-notebook-lcd-screen/
Mar 25, 2008 | HP Pavilion dv1000 Notebook
My lcd is broken on my sidekick !!!!!!!!!!!!!!!!!
Either buy the entire screen portion off Ebay which would only require you to remove the swivel portion and screen or just the LCD (which would be cheaper but a bit more work to replace, albeit simple). With a small screwdriver, remove the LCD from the phone by unscrewing the back of the screen and replacing LCD. You may still need to remove the entire screen from the base and as the swivel portion is on a coil, be mindful that it doesn't swivel after removal. I usually leave one of the screws in place to keep the screen from swiveling, otherwise, if it uncoils just wind the swivel portion to a moderate tightness and then reattach it to the unit after replacing the LCD.
Dec 03, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Computers & Internet Logo
88 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
