Question about RCA P52926 52" Rear Projection Television
Xbox 360 hd and p56926
Every time i hook up my Xbox360 with the component cable on TV setting it works just fine.
But when i switch the TV setting on the cable to HD i can no logger see the picture but i can hear it just fine.
I use the remote to switch between inputs & when i get back to Input 2 where the xbox is i can see the picture for a second before i lose it again.
And for the split second i can see the picture it is warped, so wat is normally in the center of the screen is on the edges, & the normal edges of the screen meet at the middle
http://www.xbox.com/en-US/hardware/x/xbox360componenthdcable/
look there is ya need more details on the cable.
Another quick question: wat definition can the p56926 TV go to?
much thanks
  • BluAce Feb 22, 2008
    so how long does this usually take to get a response?
  • 149 Answers
Change back to 480 resolution and them go upscaling
Posted on Mar 30, 2008
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
Hooking xbox360 up for HD in component 1
Thats the highest setting, for component, that TV will show. it really is that simple. You would need HDMI connector to possibly go any higher. but I think you will find it is the TV.
Apr 01, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Hi 4 yo x box 360 turns on fine with normal
If you are using the component cables, assuming it's the same cables that came with it 4 years ago, there is a little switch on the part that hooks up to the Xbox360. The two options are HD and Regular. Try moviing that switch to the other position. Also try another tv, friends or family if you don't have another one. Also, if you have a friend with a 360, swap out the component cables as these have been known to go bad after a while.
Nov 20, 2009 | Microsoft Xbox 360 Console
Xbox360 hd hookup problem---1080i
Your component cable is probably switched to the HD setting. You have to switch it back in order to get video when hooked up to a regular TV.
Jan 30, 2009 | Mitsubishi WS-55857 55" Rear Projection...
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
360 video problem on HDTV
I need a little bit more info on the TV its an RCA what?,
In the mean time what you could try is finding someone with a HD tv and trying it out at there house so that you can single out if it is your system or the TV. This will help alot you can also try someone else's xbox 360 at your house on your tv to see if it is your AV cable / xbox360.
Dec 31, 2007 | Microsoft Xbox 360 Console
RCA P52926 52" Rear Projection Television Logo
69 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
