Question about Gyration GO 2.4 Air Mouse/Compact Keyboard
The mouse has lost its air feature. Still works from a desk as an optical mouse. Produces a high pitched sound .
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Sorry my reply is five years after the question but I really hope this reply can help anyone out. I have a gyration GYR3101US Media center remote.
The mouse has lost its air feature. Still works - mouse-lost-its-air-feature-still-works-nec1hkrws0ash25xby3rpbkt-5-0.jpg I love this remote/air mouse but after I dropped it about two months back anytime I would try to use the air mouse, it would emit a loud high pitch sound and put the cursor near the time clock unable to move it. Tonight I took it apart. this is what I found. There is one screw behind the batteries, then you have to pry it apart with a flat head. once inside find the gyration sensor
CAREFULLY pry apart the sensor with a little flathead, there is a metal plate on the bottom of the sensor so DO NOT pry from the circuit board up that will break the sensor off. Put the screw driver between the metal plate and the outer casing you should see a little crack. also i cut most of that red tape off with a razor blade before prying.
mouse-lost-its-air-feature-still-works-nec1hkrws0ash25xby3rpbkt-5-7.jpg The red arrow is pointing at the part inside the sensor that had come lose from the drop and was moving about freely inside. I'm guessing it's a weight or magnet. After carefully and gently snapping it back in place, put your mouse back together enough to test it. at first it still had problems but i double clicked the mouse movement button and set it on a flat surface so it could calibrate itself. SUCCESS. I hope this helps my gyration is working fine now. contact me if needed john4628 AT gmail. (There are no fans or bearings in this mouse or any gyration mouse)
Posted on Feb 03, 2015
  • 2,404 Answers
Sounds like the bearing went bad on the fan. If you could take apart the mouse, I would suggest using WD-40 on the fan to possibly loosen up the bearings.
If that doesn't work then for sure the mouse is bad and would need to be replaced.
Posted on Feb 05, 2010
Hyundai accent 2005 when starting up the vechile and driving there is a constant ugly sound coming from the front passenger side wheel and when applying the brakes on there is a high pitch squeel
That screeching sound is a warning that your brake pads are worn down to the point where they should be immediately replaced. If you do not replace the pads, you'll score the rotor and incur an additional expense. Remember to replace the brake pads on both sides, i.e., driver and passenger side.
May 01, 2012 | 2005 Hyundai Accent
How to connect cordless mouse and cordless key board cordless desk top EX 1oo to desk top computer
Make sure you have fresh batteries in the mouse and keyboard:
Plug your transmitter unit into an USB port,push the connect button on the TX, then push in on the connect button on the mouse and the keyboard. Also, install the cd that came with the KB/Mouse, to gain access to the features.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holy days!
Thanks, Joe
Dec 25, 2010 | Logitech Wireless Access Duo Optical...
I have a wireless lazer mouse and key board, the mouse all of a sudden started acting eratic and the red lazer light had gone off. I tried troble shotting but it came back an said that everthing was...
common causes; -dirty optics, clean red light area with canned air. -polished or shiny desk surface. optical mice dont like shinny surfaces. try a piece of paper under the mouse to see you need a mouse pad. - batteries low. even though they have some charge, low batteries can cause erratic behavior. as the mouse and base connect then fail, then connect, then fail. ect. often people dont realize how fast optical mice eat up batteries. check the wire to the base, sometimes these get caught in sliding keyboard drawers and get damaged. hard to see untill you inspect the whole wire( to the base anyway). Animals sometimes chew em up too. :) if any of the above help you. please provide some thumbs up. Cheers
Aug 26, 2010 | Logitech 9311570403 Mouse
My mouse pointer is running all over the screen! I have tried to change the settings but no change. Please help. Annoying as heck!
first check batteries. second blow off the mouse optics with canned air third, use a mouse pad, as shiny desk surfaces will sometimes cause this. cheers
Aug 25, 2010 | Innovera Mini Wireless Optical Mouse...
Optical wireless mini mouse 98763 feature #9 is
I had all the same problems listed in fixit and found that all it took was placing all NEW batteries in the mouse.
Press the blue light button on the USB and the little black reset button on the bottom of the mouse at the same time. Worked good from there on.
Feb 23, 2010 | GE Wireless Optical Mouse
MY Logitech mouse at times will not move the cursor when on the desk but when I move it to another surface, such as my jeans, it works. Any ideas?
Opticals mouse do not work on properly on Red surface or black surface. It would also not work on a Transparent surface. Possibly the laser beam coming from the mouse gets absorbed by these surface color. Hence you need to use a surface which can reflect back the laser beam, so that the mouse pointer would move properly.
Hope this information was helpful.
Don not forget to leave your feedback
Thank you for choosing Fixya
Oct 13, 2009 | Logitech WIRELESS OPTICAL CORDLESS MOUSE...
Microsoft Wireless Optical Mouse 2000 - Laser Stays the Same
check the battery is secure in position you might have knock it loose when you dropped it
Jun 02, 2017 | Microsoft Wireless Optical Mouse...
Microsoft Wireless Optical MOuse
I've noted that certain mousepads do cause problems- it seems to be with the graphics on the pad- reflective/light/dark areas on the pad cause the different movement patterns. I'd guess a pad with a dull non-reflective & uniform color might be best.
Sep 13, 2007 | Microsoft Wireless Optical Mouse USB...
Gyration GO 2.4 Air Mouse/Compact Keyboard Logo
293 people viewed this question
Top Gyration Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony Crow
Are you a Gyration Computer and Internet Expert? Answer questions, earn points and help others
