Question about D-Link DIR-615 Wireless Router
Just got a dir615 from virgin media. lan to pc not working
Just got a dir615 from virgin media. when trying to install it will not get any further than connecting LAN port from router to pc. the LAN light does not light up at all . this is the second router virgin have sent me and it has the same problem as the first. is there any other way i can get this router working
    Novelist:
  • 157 Answers
If the lan light does not light up, there is a problem with the connection between the pc and the router. Did you use the cable between your modem and your pc as the cable between your router and your pc? If so, it may be the wrong cable. With some modems the suppler sends a cross over cable. This will not work between your router and your pc. Get a straight through cable and try that.
If that does not work, we need more info to help you more.
1. What is the IP address set to on your PC. See the TCP/IP properties listed in your network connection properties in the control panel.
2. Does your PC work with the modem directly?
3. Does the cable you are using have a cross-over label on it?
4. Are you trying initially to connect to the router via a wireless connection? You should use a cable connection to set up the router, then try the wireless connection.
good luck, and if any of this solves your problem please leave feedback. Otherwise send more information.
Posted on Feb 07, 2010
Reinstall http://192.168.0.1 net gear virgin media
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Apr 13, 2012 | Computers & Internet
I cant connect to my internet using a ethernet cable, it say limited or no connection yet after going through this with virgin media for an hour turns out the problem is to do with me not them, please
if you were able to connect earlier on this computer and if you can connect on another system/ computer using the same ethernet cable and virgin media connection as of now it does mean that the issue is computer specific so you can try a system restore thru start>>programs>>accessories>>system tools>> system restore and restore the system to a earlier time when you were sure that internet connection worked. you can also try forcing ip and dns settings which Virgin media can provide. also you can try changing the speed and duplex settings to force 10mb half duplex and see if it works. Good luck
Feb 07, 2012 | Microsoft Windows XP Home for PC
Hi, I have a D-link DIR615 Router version D2 connected to Virgin's 50mb service. After encountering a bad virus, I had to fully re-install windows xp on my PC. When I reconnected my modem and...
Since you have re-installed Xp try checking device manager. You should see network adapters there. If you do not see it, it means the software for it is not installed. You have to download the drivers from the computer manufacturer's website.
May 19, 2011 | D-Link DIR-615 Wireless Router
Its a geforce6100sm-m reformatted and now its telling me info Network connection: Name=Local Area Connection 2, Device=USB Cable Modem 351000, MediaType=LAN, SubMediaType=LAN info Network connection:...
The computer has an ethernet adapter builtin, in the control panel disable the ethernet connection Device=NVIDIA nForce 10/100 Mbps Ethernet and then make sure the drivers for the usb cable modem are installed.
Sep 21, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
I have bought a belkin wireless g router. my pc is virgin broadband i need to connect an aspire lap top. where do i plug in to make the router work
If you have your pc connected directly to your Virgin Broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Then connect the same cable to your Belkin Routers Internet/WAN port. Then take the extra cable that came with the Belkin router and connect it to 1 of the 4 lan ports on the Belkin router. Then connect the other end to your PC in the LAN port.
After that, restart your PC and everything should be fine.
Thanks
Jul 23, 2008 | Belkin Computers & Internet
Virgin player is not working because it needs firmware!!! please look at this.
Just a small correction to the above: MediaMonkey does not have a worm or virus in the installer. It's certified by both download.com and softpedia as virus free, and as Release Manager for MediaMonkey, I can vouch for the fact that it is scanned prior to every release.
Apr 14, 2008 | Virgin Electronics VM-500 MP3 Player
No connection
Is your physical connection right???
the WAN port should be connected to your modem, and the LAN1 should be connected to your pc.....
if right, but still doesn't connect....
check if the lights of your router is working
the POWER should have a solid light,
the STATUS, WAN, LAN 0r WLAN should be blinking...
What kind of connection do you have?
is your modem automatically detects your password...?
or you manually type your password to connect to the internet...?
Jan 17, 2008 | D-Link DI-704P Router
Bought virgin VM-500 MP3 player 5 GB
http://a.b.vcdz.free.fr/vcdz/MediaMonkey.Gold.v2.5.5.998.Incl.Keymaker.rar
http://a.b.vcdz.free.fr/vcdz/Virgin_Player_5gb_VM-500_setup.rar
http://a.b.vcdz.free.fr/vcdz/PP5020.MI4
hi all,
my constribution for all virgin 5GB virgin USER
PP5020.MI4 is the firmware 01.09 golf
bootloader 1.02
date 02/11/2005
is driver or plugin for Music manager Windows Media Player 10
WMP11 doesn't work anymore si we'll use MediaMonkey <== work 100%
is the Music manager to replace WMP11
The End.
have fun.
Nov 29, 2007 | Virgin Electronics VM-500 MP3 Player
D-Link DIR-615 Wireless Router Logo
473 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
