Cassette player motor not working
I was given a second-hand B&O casette player and after I cleaned all the fluff out it did work for a while but then stopped and hasn't started since?
  • 378 Answers
The Belts of the cassette player need replacement.
Posted on Feb 05, 2010
Car casette player won't accept cassettes. I put a cassette in and it spits it right back out.
Your casette player must have something lodged in it that's why it spits the casette tape back out. If you are able to, try dislodging the player from your dashboard. Shake it and if there's something noisy inside, chances are that's your culprit. Try to get it out by shaking the player while keeping the casette tape door open - like getting coins from a piggy bank. :)
Hope this helps!
Fix14
Jun 16, 2010 | Car Audio & Video
How to takeout the stuckup video casette form sony vcr and repairing the auto casette take-in take-out system
remove the vcr´s cover and manually turn the motor´s pulley that charge the cassette, if you do not know which is the motor, put atention which motor is turning while you plug the vcr at outlet. Do not forget give points.
Apr 17, 2010 | Sony RDR-VX525 DVD Recorder/VCR
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
B & O Beocenter 4600: The record player won't spin
the turntable wont spin unless a record is on the platter,the centre 45 adapter weighs the record to determine 33/45.try pressing 33 and turning the platter by hand(remove expensive cartridge first!),if it starts to spin the motor leaf switch is at fault.is the belt in position.the motor pulley can become unglued.
Jan 08, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
Need wiring diagram for factory chrysler new yorker radio
2 things
1 sounds like the amp is fryed
2 sounds like the belt on the casett deck is broken
salvage yards sell radios cheep like 20 -30 bucks usualy if you remove it your self
May 28, 2009 | 1991 Chrysler New Yorker
Casette
You could have one of several problems. The cleaning message comes up when the camcorder cannot read the signal from the tape properly. This can be caused by:
1) A dirty video head
2) the tape guides being out of alignment
3) A worn or broken video head
If a cleaning cassette head does not help, you will need a tech to look at it.
Oct 18, 2008 | JVC GR-D90U Camcorder
Sony dual casette player/recorder
Unit may have slipping drive due to defective belt or tape may have wrapped around captsan. Have serviced
Jul 28, 2008 | Sony Dual-Deck Cassette Player/Recorder...
Reinsert cassette
not a problem recognizing the tape but a problem with the casette mecanism, swtiches. it has to be serviced and cleaned
May 03, 2008 | Sony Hi8 Hi-8 Tape
Yahama MT8X 8 track mixer cassette unit
I believe this unit employs an optical sensor to detect tape end.
Clean this off to. It looks like a transparent post positioned along the tape path. Reset the counter to zero and fast forward tape to end. Rewind, and try to play tape as normal
Apr 08, 2008 | Audio Players & Recorders
Loud clicking
Open the cassette deck and use a pen to push down the heads. After this it probably works better to avoid using cassettes in this machine.
Feb 16, 2008 | Sony MHC-RXD3 CD Shelf System
Open Questions:
70 people viewed this question
 Grubhead
Grubhead
