Question about SanDisk Sansa Connect MP3 Player
I need help!!
Can you please tell me why my sandisk connect's usb cables are showing up on my windows media player as unknown device detected when i have everything i need to get it on there and get music on there on my computer??? please....
How i get songs on it
Posted on Feb 21, 2008
Sansa e250 MP3 Player: The computer won't acknowledge that my Sansa E250 ...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ......
May 16, 2010 | SanDisk Sansa e250 MP3 Player
Sansa e250 MP3 Player: won't play any music or change to any other format...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ........
My Red Sansa Clip 4GB will not show on any computer i plug it into, It only charges and i have tried the auto detect, mtp, and msc settings. Any Suggestions?
May 17, 2010 | SanDisk Sansa Clip MP3 Player
Cant not download on windows vista without disk for sansa c240
> basic info
Support info for the c200 series players:
http://kb.sandisk.com/app/answers/detail/a_id/4487/session/L3NpZC85cE94WVlZag%3D%3D/sno/0#c200
Answer pages for c200 and c240 related players:
http://kb.sandisk.com/app/answers/list/p/555%2C662%2C646%2C653%2C654/r_id/101834/search/1
> connection mode
The player can operate in either MSC or MTP mode.
MSC = Mass Storage Class, seeing the player as a removable disk.
In this mode you can transfer with copy and paste or drag and drop
method.
note
Before disconnecting in MSC mode always go through the icon right below "safely remove hardware": remove the player in the icon before taking out the USB cable.
MTP = Media Transfer Protocol, having the player connected in software
e.g. Windows Media Player.
note
Disconnect the player only after the dialog in the software tells you can disconnect the player or transfers have been finished.
USB connection mode can be set in the menu, it can be
auto detect
MSC
MTP
Look in the manual for this setup.
c200 series version 1:
http://mp3support.sandisk.com/downloads/um/c200-ug-eng.pdf
c200 series version 2:
http://mp3support.sandisk.com/downloads/um/c200v2-um-eng.pdf
USB connection mode can also be forced into MSC mode on the version 2 player (default connection version 2 player is MTP mode):
1. Turn device OFF.
2. Slide the hold switch to the direction of the REC button so an orange color would show putting the device on Hold.
3. Press and hold the left ( |<< ) button while connecting the device to the PC.
> recognizing in MTP mode
When an MTP device is not recognized in Windows Media Player 11:
http://kb.sandisk.com/app/answers/detail/a_id/36/kw/vista/p/555%2C662%2C646%2C653%2C654/r_id/101834
FIX from Microsoft for Media Transfer Protocol related player / USB devices:
> about compatible SD cards
Differences between version 1 and 2, c200 series players:
http://kb.sandisk.com/app/answers/detail/a_id/194/sno/0
Hope this is enough information to get the downloads you want.
Just add a comment when needing more help.
Apr 09, 2010 | SanDisk Sansa c240 MP3 Player
When I plug my Sansa Fuze (8 GB) into the computer it won't download the driver into the computer.
if u have a installer cd with the device then
please install the driver then plug your device
in the connectivity cable.
Dec 28, 2009 | SanDisk Sansa Fuze MP3 Player
Helppppppp!!!!
There is a problem with the USB cable or your USB ports - check Start--> Control Panel--> Printers and Other Hardware --> system --> Hardware--> device Manager-->USB Controllers for more detials (I am assuming Windows XP) - see if there is a yellow exclamation by your USB port
or
try a different usb port or cable
or read my "tips and tricks" on sansa players
or
Go to sansa's website
You are sure to find some sort of answer
-Tha Mp3 Doctor
May 29, 2008 | SanDisk Sansa e250 MP3 Player
Sansa M230 not seen in Explorer or Windows Media Player
We had the same problem with Windows XP. We found some help on the Sandisk web site. On the device go to the Settings menu, then USB. We changed from AutoDetect to MSC mode and everything is working again. Our computer saw all of the songs on our computer fine. Some of the old songs on the Sansa didn't show up on the detect list in Windows Media Player, but they were still on the device.
Mar 23, 2008 | SanDisk Sansa m230 MP3 Player
All sansas
Update your USB drivers?
You could try putting the Sansa's in MSC mode.
Depending on your Firmware there will be a USB option under settings (Under USB it might be on Auto just select MSC)
OR you will need to
1)have the player on (but not plugged in)
2)push the HOLD switch tot he right (towards the REC button [see orange in the hold slot]
3)HOLD DOWN the |<< rewind button (keep this held down)
4)plug the cable into the Sansa (assuming the other end is in the USB port)
Wait till you hear it detect it..
If it still does not..
CHECK the Device Manager to SEE if their are any unknown devices under USB unplug the Sansa
Delete the unknown and try steps 1 thru 4 again.
If you do not know how to get to Device Manager then you will need the help of someone who knows these types of things to show you or look this up on the internet.
Dec 09, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
WMP won't detect my MP3
See if this helps: -Close all programmes on your computer. -Turn off your Sansa e250. -Attach the cable into the USB port of your computer before attaching it into the actual e250. -The scroll wheel on the Sansa should have turned on by now. -Then it's just a matter of waiting for a few seconds. -Try opening Windows Media Player to see if it detects your device. Otherwise, be patient. Goodluck.
Mar 15, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Connect  MP3 Player Logo
19 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
