Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
My KDF 60XS955 Sony WEGA TV keeps shutting off every couple of minutes. Then it restarts. Do you know what the issue and fix are?
  • 1 more comment
  • walley2 Feb 05, 2010
    Thanks,
    are the Less expensive Philips Lamps as good as the original SOny Lamp?
    What do you mean by "remain Safe"
    Excellent help and response
    Mark Miller
  • 10,594 Answers
If your Sony KDF-60XS955 shuts down and turns on itself again then it is symptom of weak lamp that is causing problem.
Replace lamp in tv and all will be OK.
Lamp replacement procedure is easy and would be mentioned in user manual. Click Sony Support to download user manual copy, if needed, check page-16
Required lamp part number is as follows..
A1085447A... LAMP BLOCK ASSY XL-2200U
and available in Sony Accessories Store for $200
Hope this info will solve your tv problem.
Thanks.
Posted on Feb 05, 2010
  • Shahid Electronics
    Shahid Electronics Feb 05, 2010
    Thanks,
    I would recommend Sony original lamp for tv safety as price is bit high but tv will remain safe for next few years.
    Less price/ alternate lamp is not same as Sony original lamp.
    Ballast lamp produce heat while producing light so my point of view is less price lamp might produce more heat that can damage light engine internal parts on long run.
    Saving few $$ is good thing but should not be on tv cost.
    Thanks.
Sony grand wega randomly shuts off for about 15-30 seconds every 10 minutes. Fairly annoying
No lights?? Are all fans running properly? Check for dust buildup and clean out. Dust can slow down the fans enough to shut it down. Sounds like a cooling issue.
Oct 02, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Power keeps going on and off
Model number posted in question that is KDF-60SX955 shows it is Sony dlp tv, if tv shuts down and turns On itself then reason is weak lamp that is near to end of its working life and need to be replaced to fix this issue.
Lamp replacement procedure is written in user manual and its easy. Please buy Sony original lamp for good quality picture in tv.
Let me know if you have additional question.
Thanks.
Apr 18, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
My sony grand wega kdf-60XS955 dont turn on
Power suppply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KDF-E50A10 Shuts off and on every 1- 2 mintues
From what it seems in your question... the problem has already went away... However, I actually know about this. There is a fuse inside the tv near the power button called B-3a... If you replace that fuse it should help fix permanently
Dec 17, 2017 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDF-60XS955 shuts off intermittingly and red light flashes 5 times.
My KDF 60XS955 turned on and off like the above complaints. I had an appointment with a Sony Repair specialist but thought that since my bulb was getting really old and taking too long to warm up, I would change it before he came and tried to sell me one at retail cost. I then noticed that the set didn't turn off any more. I ran it that way for a week and then decided to put the old bulb back in and see what happened. Within 1/2 hour it had turned off twice so I changed it back and said that fixed it. I cancelled the sony tech and saved some money. I hope this works for some of you also.
May 26, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
156 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
