Hello - I am sure hoping that you can point me in the right direction as I deal with the frustration of my washing machine. I'm having trouble with my Roper Top Loading Washer - RAS7233KQO Lately, I've been noticing that the clothes are left very wet after the washer is done. I began investigating the possiblities. The easiest was the timer and the lid switch - all is well with these two things. I then decided to begin watching different wash sessions to see what was going on. Everything progresses as it should until it reaches the spin cycle - kind of. When the washer has an average load in it, it either spins very slow or you can see it trying to spin or sometimes it won't spin at all. I then decided to test the washer by putting just a couple small items it it. I ran the washer. It reached the spin cycle and spun like crazy BUT - the couple of clothes that I put in were still very wet. Help! Is this a spin problem or a pump problem? What would you suggest we look into to diagnose the problem? Please point me in the right direction. Any help you could offer would be such a blessing to our family. Thanks and God Bless!
I would probably not focus on the pump but instead check the clutch/transmission assy. pull the cover off, is there oil spread across the inside cabinet apporx 12in. up on all 3 sides, thes an indicator of bad tranny, oil on clutch =intremmitten spin
I would check your pump the slow spin can be cause due to yhe water still in the outer tub. post your email and I will send you the guide on how to check this
My email is [email protected]
Thanks for your helpful solution. I will be willing to try anything you send. I did want to make it clear that there is never much to very little standing water in the tub when the cycle is done. I do hear sloshing water inside the "outer tub" like you stated.
Thanks again.
I would be willing to try anything you would send.
As far as the standing water, I can hear it slosh sometimes, but there is not very much or very little visable inside the tube.
same problem washes fine spins slow i peek in while it spins and i can see it.. sometimes vey slow and somtimes faster but no where as fast as it should
