Question about Maytag Neptune MCE8000AY Electric Dryer
My neptune dry has trouble starting. It makes a loud humming sound and then starts up. If you open the door and then try to restart it, it just hums. Someone to me it maybe the start switch or start relay on the motor, or the motor going bad?
    Genius:
  • 1,122 Answers
Motor going bad is correct,it will get to the point where it will only humm because it is to weak to turn the motor-mike
Posted on Feb 05, 2010
The fan is making a humming sound
when door open Temp inside goes up, when close door it tries ti bring temp inside back to where it needs it also it will generally only try to work when in closed environment don't sound like any "Fault" tho
Aug 22, 2015 | Samsung RF265AB (258 cu ft) Bottom Freezer...
I have a ge sisde by side model#gss25rgma ww. the fridge/freezer is working good, but now not making ice, it has started to make a really loud humming type sound if the doors are left open to long than...
Sounds like a evaporator fan motor problem. However remove rear panel and if slight frost on top of evaporator replace motor if not post back or call professional
Oct 02, 2017 | Refrigerators
Making humming noise power not on door locked
turn off the unit.use a wet dry shop vac and attach it to the end of the drain hose this will remove all the water then you can turn it back on and should be able to open the door to get your clothes out.
after all thatis done you need to check the drain pump and make sure there is nothing blocking the pump.other likely problems are the door lock mechanism is bad or the main control board
Jul 05, 2010 | GE Energy Star WCVH6260F Front Load Washer
My neptune washer won't start a cycle, just hums. I can't open the door to get the clothes out.
here is a trouble tree code chart for your washer
down load it and save it for future reference
http://www.applianceaid.com/neptune8.html
May 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
My sub zero 642 just starting making a humming
It is your evaporator fan. When the door opens power is cut to the fan motor.
Apr 29, 2010 | Sub-Zero 642
My neptune dryer sounds like it is going to start but then fails
sounds like a bad motor. when it hums when you push start, open the door. put a piece of tape on the door switch to hold it in. at the same time, push the start button and turn the tub with your other hand. if it starts, this only confirms it is a bad motor. the motor will need replaced. good luck. shane
Jul 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My Mag neptune dryer shows HP and stops drying
Hi again mssunnybunny,
I just thought of something,
You did not give a lot of details so pose this question just in case!
You only said, Your Mag Neptune dryer shows HP and stops drying!!!!!!!!!!!
1.Does it go but not get hot and not drying??
2.Or does your dryer not go and then make a loud humming sound like it's trying to go??.
If # 2 is the description and this was the case, then you need
a new motor!
Sep 13, 2008 | Maytag Dryers
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag Neptune MCE8000AY Electric Dryer Logo
73 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
