Question about PC Chips M860 Motherboard
Usb does not work - PC Chips M860 Motherboard
  • Mike Peluso
    Mike Peluso May 11, 2010
    Enter the bios and go through every setting. Make sure the USB setting is set to enable.
    Guru:
  • 239 Answers
Normally this happens when the southbrigde chip on ur mobo is faulty
Try other solutions by visiting manufacturer's website support
Posted on Feb 05, 2010
Samsung r519 usb ic
All USB not working? If not remove USB device re-boot and then re insert USB device. Still does not work check Device Manager look for any errors under the USB list. That said, how old is your Samsung and what are you using in your USB port?
Oct 29, 2012 | Samsung R519-53S Notebook
Usb header not working
Usb ports are bogus. You can always install a pci usb card though. Beats replacing the mo bo since you have already tried everything else to no avail.
Apr 15, 2017 | ASUS M2N-MX SE Motherboard
Usb damage
If all the USB ports fail to function, then repairing them is difficult, as the problem will be with the USB controller on the motherboard. If one or two fail to work, but the other ones work, then you have the option of putting a USB extension port into the working USB socket and that will allow you to run several devices from the one port, or, depending on the laptop in question, you can get a USB adaptor PCIMCIA card or Cardbus card that will plug into the expansion slot on the laptop and will give you a more permanent USB solution.
For this to work, there must be at least ONE working USB port
Jul 21, 2011 | Computers & Internet
Window7 crache connecting usb fax modem
I expect it is a problem with your USB Driver, Get an updated driver for your USB slots. (either from motherboard manufacturer or USB manufacturer if it is a USB "card")
Even default or old drivers might work Try a few different USB drivers - a new one, the reccomended one, the original one...
(good idea is to use a ps/2 mouse and keyboard since your usb will be going on and off while you're working, it can be hard to click YES when you're keyboard AND mouse aren't working ;-)
if it still dont work...
Can you set any of your USB slots to work in USB 1.0 instead of 2.0, there could be an option in bios, maybe it will run the "OLD" modem in an OLD mode?
Jan 21, 2010 | Computers & Internet
Usb mouse
here is what you can try,
1. try to connect the usb mouse in the other usb ports to check if it works
2. try another usb mouse.
if the usb mouse works in other ports and not in some of them...USB ports gone bad.
if it does not work anywhere, the mouse has gone bad. also to check the usb ports check if keybaord works or not. if yes..its just the mouse. it cost approximately $10. go and get a new one.
Sep 21, 2009 | Computers & Internet
I have a WD passport 320gb, at first it worked one of my usb. then all of sudden, it stop recognizing my WD Passport with one usd port, so i plug it in another usb then it works. and after a couple of days...
Are you using an external power supply for the disk? If not, you might be overloading the USB port. It should not happen, but USB ports are limited in the amount of power they can output. Especially laptops might face such problems.
Do other USB devices still work on those USB ports? If so then the port is at least not broken.
Sometimes you can uninstall and reinstall the USB hubs and controller devices in the Device Manager to fix USB problems.
For other ideas on troubleshooting external hard disk issues, you can check: www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Jun 13, 2009 | Western Digital Passport WDXML800UE...
Usb not working
Check that all the USB ports are turned on in the BIOS setup.
Apr 02, 2009 | PC Chips (M925G) Motherboard
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
Usb problems
Have you checked that they are correctly wired or jumper set on The System Motherboard.
Mike @ compurepair.
Apr 19, 2008 | Intel D102GGC2 Motherboard
The orange light on my usb wont turn on. it was working just fine 2 days ago. after my last use i put it on top of my dresser and never touched it. Can someone please identify the problem when the orange...
Very good in checking if your computers' USB ports are working. Now that you know that your computer's USB ports are working, try your USB device on his computer and check if it'll work there. If it also doesn't work there, then it'll be your USB device that's not being read.
Jan 01, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
PC Chips M860 Motherboard Logo
43 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Steven Burn
Steven Burn
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
