Question about Cell Phones
There are 3 circles seems to me like lights at the top of phone what is it? ECO24*7
My 2001 Kia Spectra's ac just started giving me problems. I will be driving and the cold air stops blowing then it will start again. It's as if the compressor goes on and off. I did recharge it so when...
Note the diagram. With the ac on, vehicle in park, engine running, raise the hood, when problem is ongoing, is the compressor clutch engaged? Sometimes, you can tell. The top circle is ac relay. The bottom circle should be magnetic clutch/compressor. At the compressor clutch, top wire in diagram, I believe it is green and yellow, It should have voltage, use a test light to check. It appears to ground through compressor body. Voltage and grounds are important.
The compressor body won't get any voltage unless ac relay is energized. Top circle. The relay has two sides, load side and control side, The load side is that line with arrowhead, the control side is the right side, in the circle. You can see ac fuse above relay. The control side needs voltage and ground.
Another thought, temp door under the dash has a problem? Any applicable trouble codes?
Oct 05, 2017 | Kia Spectra Cars & Trucks
How to disassemble LG u8180
To disassemble your phone, please follow the steps below.
  • Turn your phone over so the battery cover is facing you. Remove the battery cover and battery. Next remove the 2 rubber stoppers (circled below) and unscrew the aerial.
  • Remove the 6 screws (circled below)
  • Next remove the 2 rubber stoppers & screws above the main screen (circled below)
  • Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet (as shown below)
  • Your phone should now look like the picture below. Unclip the ribbon (circled below)
  • After removing the ribbon cable (above), carefully lift the metal part indicated by the arrow above. Another ribbon will be attached which should be carefully removed. Take the circuit board & keypad out and you'll be left with what's below. Next remove the top part of the phone by pushing the housing in whilst pulling the hinge, which the top part is attached via, away from the phone. This is the hardest part and you'll need to bend and manipulate the housing the get the hinge out. Be firm but be careful so you don't snap the housing.
  • Your phone will now be in two parts. To open the top half of the phone and get to the screen, run your fingernail fingernail between where the two parts of the housing meet (as shown below)
  • Your phone should now be as pictured below. The circled areas indicate where you'll need to remove the speaker and ringer in order to solder them to the new screen. The screen can be lifted away from the phone easily at this point.
  • Remove the LCD and replace with new. Reverse the procedure for disassembly and it's finished.
Take care and good luck
Take note, the pictures are that of lg u8120, it has the same disassemble process as lg u8180
Oct 27, 2010 | Cell Phones
Lit cam on a circle-open at the top with exclamation mark in cent
Low tire warning light. All the tires have a sensor in each. You may need some air and or a tire repair.Possibel bad sensor in some cases.
Apr 15, 2010 | 2000 Volkswagen Beetle
KS360 pink flashing circle, can't get phone on
Phoned Orange (who the phone is with) they are sending out a new one. Fault is on the phone.
May 18, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Mar 03, 2009 | Bulova Watch
Warning lights on land rover dicovery 1993
A circle with lines around it - depends where it is -
If its a top left light, then it should be a circle with an exclamation mark in the middle, and two lines running part way round the outside (1 to 5pm and 7 - 11pm). Thats the handbrake and brake fluid light which comes on for about 3 seconds when you start the engine ... if it comes on at any other time - seek help.
If its top centre, and has ABS in the middle, then its the anti lock braking light. Similar to above, lights up for a few seconds at start.
Muffler with lines coming off it - are they pointing outwards from the circle, (with a thermometer in the middle = transmission oil temperature guage), or are they on the left and all parallel (which would be main beam indicator, which lights up blue when on)
Feb 15, 2009 | 1995 Land Rover Discovery
Can't select multiplayer
you need to hit the round X button the middle of both controllers and set which profile they will use.
Do it on controller 1 first then controller 2
Jan 07, 2009 | Microsoft Xbox 360 Console
K850i mobile switching on problem
you say the phone powers up and lights the keypad and the camera blue circle... has this phone EVER been in contact with liquid,or dropped / sat on? have you tried to unlock this phone yourself,or has someone else tried for you? it seems like there is some sort of liquid issue here that had made the phone dysfunction...and i have seen cases like this where the phone gets wet,has fallen in some drink,and you try to dry it out and think it is going to be ok because it lights up... is this what has happened? if this is the case then there is no solution to your problem apart from get another phone and take care not to let it come into contact with liquids of any kind..(even rain )
or yet again the firmware/ flashware has been rendered useless.. this would be either by a bad unlock or as above,liquid contact
Dec 02, 2008 | Sony Ericsson K850i Mobile Phone
My instrument panel has a light on
hi i think that light just means there is a bulb gone..
Nov 09, 2008 | 1990 Jaguar XJ6
Keypad backlight erratic
There is a small opaque circle just above right soft-key. Put a small piece of black plastic electrical tape over it and keypad lights all the time. This circle apparently is a so-called "battery saver" which senses light in the area so unless you're in a dark area keypad will not light. There is absolutely no mention if this in the manual that I can find.
Aug 22, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
