Question about Sony Xplod XM-1652Z Car Audio Amplifier
Xm 1002 hx
The offset light is amber. The manual reads to check the ground on speakers and to the unit both are good but I still cant get the light to turn green
  • 25 Answers
1. What type of head unit are you using
2. does the head unit have a Loud feature?
- Sometimes you have to press the loud button on certain head units to engage the amplifier.
Try disconnecting your remote wire from the amplifier, grabbing a piece of small 12 or 16 gauge wire and bridging the remote wire with the (+) on the amplifier. if your light does not turn green, then check your fuse and the ground for the amplifier itself and the subwoofers.
When you connect the remote wire to the (+) it should automatically turn the amplifier on even if the cd player isnt on. The reason I want you to try to connect the remote and power is because sometimes the remote wire for the cd player is bad. If it does end up being a bad remote wire from the head unit, then your best fix would be to connect the red wire (ignition 12v) on your head unit to an on/off switch to the remote on your amplifier. You can then turn your amplifier on and off by flipping the switch. If you go to autozone or advanced auto parts you can pick up a toggle switch for about $3.00.
Posted on Feb 24, 2008
Installed amp and offset light comes on, no sound out of speakers
  • You have a ground loop somewhere. You need to check where your amp is screwed into at and make sure it is not to the metal on the car itself. Check your Power and Ground wire connections good to. What's happening is your amp is generating unnecessary DC current. Find your loose or shorted connection and this will go away. The majority of the time you have a loose or insufficient ground connection.
Regards, Tony
May 20, 2011 | Sony XM-1502SX Car Audio Amplifier
My off set light is on even after i unhook my rca and speakers how do i fix this
offset light is on when coonected amp, groung is good, wires fine, tried another amp and works fine , what the heck. is the amp no good
Oct 27, 2010 | Sony XM-1502SX Car Audio Amplifier
I have Sony XM-2150GSX amp on offset cant get it off
check for a short on one of the edges or a resistor on the edge of the board
Jul 04, 2009 | Sony XM-2150GSX Car Audio Amplifier
I can't turn on
The circuit is blown a couple of the connectors crossed. It is going in protect mode to keep it from further damaging the internal electronics. Open it up and double check all connections.But if you don't have any idea how to check it then i suggest you to take it for a repair,the cost will be between $100-$150.
You have to get it serviced and replace whatever has blown up inside and after that you won't get the protected message again.
Goodluck..
Feb 14, 2008 | JVC HX-D7 Shelf System
Need a lil ore help!!!
If the overcurrent of DC offset lights are not green, the amplifier probably has blown output transistors.
To eliminate other problems, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally (all lights green), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Jan 05, 2008 | Sony XM-2150GSX Car Audio Amplifier
Red lioght keeps comming on
Make sure ohm load is not too low, I think that amp is 2ohms/ch and 4ohms bridged minimum.
Oct 29, 2007 | Sony XM-1252GTR Car Audio Amplifier
Sony XM-2200GTX...Power, Green Light, All OK, No Sound!
Sony generally drives their power light from a source that does not rely on the amplifier's switching power supply. This means that it's not a good indicator as to the health of the amplifier.
As long as you have B+ and remote voltage, it will light up. Since you've tested the speaker and the signal source, I think the amplifier is likely defective.
Oct 17, 2007 | Sony XM-2200GTX Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
181 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
