Question about Toshiba 36A40 36" TV
Toshiba TV sound vanished
27"Toshiba tv/dvd combo. one channel sound vanished and then another one; now 7 channels have no sound; this rate all the channels will go silent soon. Help will be greatly appreciated. Thanks
    Scholar:
  • 50 Answers
It is possible that the TV set has an SAP (secondary audio program) setting that has been turned on. To check this go in the the menu, find audio settings, usually the correct setting for this is Stereo, other setting may include Mono, Surr-Stereo, etc.
Posted on Feb 05, 2010
No picture model Toshiba TV model #32c100u2 get
Does it have a DVD player Combo unit ???
Aug 16, 2013 | Toshiba Televison & Video
I have a toshiba mw27f51 27 in tv and want to hook up to dish network. There is a cable from the dish network box but the tv does not get reception
I am hoping that you have gotten this resolved. But if not, or if you have trouble in the future, here are some simple steps to run through. If you are at TV1, the location where the receiver box is, then you want to make sure that your tv is on channel 3 or 4. Depending on what cables you have, the tv may also need to be on an input, such as video 1 or 2. In this case, it sounds like 3 or 4 would be sufficient. If you are in TV2, where there is no receiver box, you want to make sure that your tv on channel 60 or 73. Hope this helps!!
Becki Barned
DISH Network Customer Service
Oct 19, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Need to know what channel my TV needs to be on to watch DVD/VCR
The channel you use depends on how you have the vcr/dvd player wired to it. If you used a co-axial wire, then your tv should be on channel 3. If you used RCA wires, then you will have a button, either on the front of the tv, on the remote, or both that says "input" or "source". Pressing this will change the TV to the rca connectors. Try this and let me know if it helps :)
May 16, 2009 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
Channel Changing
Some TV's have a 115 to 125 channel limit then will go to video in and then channel 2 and start over. Your TV's tuner may not have the ability to decode those channels. My suggestion would be to get a set top box (cable box) that can access channels. Your provider should have these or can suggest where to get one. Probably less expensive than a new TV.
Sep 24, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Switching from TV to CATV
it sounds like the tv is already in cable mode, and that it is a older tv. some older tv's will only tune in so many channels. yours going up only to channel 69. if you have the remote for this tv, try punching in channel 73. if it doesn't tune in, then the tv will not recieve channel 73.
good luck
wg
Feb 05, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Can't get TV onto the AUX channel
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
Dec 15, 2007 | Toshiba 27D46 27" TV
Problems with Emerson EWC27T3 27 in. TV/VCR/DVD Combo
You'll need to set your audio options to back to normal, not SAP...accordianman
Oct 12, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
I can not get a TV signal to work with the Toshiba through coax.
bill24 sorry to be the one to tell ya but you need to go into setup on the tv to setup the channels in the menu and the memory and the only way is to do it with an original remote. BUT your in LUCK. http://remotes.com or 1-800- remotes has the remote you need for $27.38 + shipping. Good Luck
May 27, 2006 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Toshiba 36A40 36" TV Logo
431 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
