Question about Pioneer Audio Players & Recorders
Power Indicator dead On Pioneer A400
I have a Pioneer A400 amp which is working fine. The only thing is the power indicator light went off but the amp still works fine. Could this be an indication that something is wrong, or is it just the bulb/neon has blown.
Thanks,
Harvey.
  • hstaples261 Feb 06, 2010
    Hi Anthony,
    Thanks for your answer. There is no smell of burning at all. When I recieved the unit there was nearly a blanket of fluff inside. I vacuumed it all out with a special vacuum cleaner with a rubber nozzel. The inside now looks like new. I tried the amp again today and the or LED is back on again. So you could be right, ie bad solder join. Just to point out when the LED light went off I heard a click like a relay, but the amp carried on working fine.
    Thanks again,
    Harvey.
    I might just leave it for now as it is working fine apart from the LED going out after the amp has been on for awhile. I am going to monitor the amp closely and see how long it takes for the LED to go out. Then I will examine the main board with a magnifying glass to see if I can find any dry joints and reheat as neccesary.
    Harvey.
    Sergeant:
  • 226 Answers
Hi, yes don't worry about it if you are sure it is working fine,it's just one of those things. Can you smell any sort of burning?
if not don't worry, but if you know someone who knows a little about electronics, it might just be a bad soldered connect on the neon, but neons are prone to blowing.
Well i'm just blabbering on here.
if it's ok leave well alone.
I hope this has helped in a sort of way.
Regards - Anthony
Posted on Feb 06, 2010
  • Anthony Feb 06, 2010
    If all is well, then leave alone.
    HAve you tried going to a college and asking an electronics repair teacher if they could look at it with you there.
    When I was doing electronics servicing we sometimes did this for people, it might be worth asking to see if it is a dry joint.
    Hope this helps - Anthony
    OK, good luck anyway, but give us a shout if you need more help.
    Regards - Anthony
CDJ-800 Mk1 No sound output!!!
Not true! CD channels don't require a pre-amp and the cartridge for a turntable does. I suspect that when the power went off the mixer was still on, so that when power was restored it came back on. However this resulted in a surge inside the unit. Magnetic cartridge pre-amps are often very sensitive to this kind of thing and will sometimes fail, while everything else works fine. This would result in no sound from the record decks, but sound from CD players etc.
Apr 13, 2013 | Pioneer CDJ-800 Turntable
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sansui A-909 LED indicator(peak power meter)
Check you have 14 volts on pin 3 of the driver chip for the meter.
Apr 05, 2017 | Audio Players & Recorders
Hi . Entered our garage on an angle & indicator light did not switch off for quite a few hours before we noticed it . Does this frequently if dont come in to park straight. Battery on our cts cadillac...
When the battery went dead, it activated the anti theft system. That is why you can't get the key out of the ignition. If you do get it out, you still won't be able to start the car. Call the dealership and ask them what your options are, in the meantime, go to this website and read about the security sydtem: http://newtockies.ca/vatsbypass.
Dec 27, 2010 | Cadillac CTS Cars & Trucks
Does the power indicator light stay constant when power is on or does it flash?? pioneer gm-5400t amp
should stay on . I suspect it is in protection mode . disconnect ALL input rca,s and speakers then try again to power it up. if still no good it could be blown. check fuses etc .
Jun 16, 2010 | Pioneer GM5400T 2-Channel Bridgeable...
My TV won't turn on
Ur tv have LED front panel power indicator light blinking?Or completely dead,no LED light indicator at all?Check ur power outlet source.Yes,than ur power supply board it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 28, 2010 | Soyo DYLT032D 32 in. LCD Television
Pioneer Plasma TV-PDP-4270HD won't turn on. TV
Try this! There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
Mar 16, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
Hi I have a 94 chevy g20 that the blinkers aren't flashing. Hazard lights are working fine. Walk around the van no lights are dead. Check all fuse everything is good. Any help would be great.
check the indicator flasher or relay that operate the blinkers or indicator light & hazard light system, check the combination switch for proper working if problem with it better replace it, if you are not able to solve the problem better take vehicle to nearest GM workshop for proper repair & checkup to be done & get the problem solve
Jul 22, 2009 | 1994 Chevrolet G20
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
139 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
