Question about Konica Minolta magicolor 2430 DL Laser Printer
Toner Cartage I inserted a new black toner cartage (1710587-0040) in a Konica Manolta Printer 2430 DL. After putting the cartage in the machine the message still says "End Black Ink". What must I do to get the printer to print?
  • 3 more comments
  • bustedupcpu Mar 03, 2008
    My printer says all the color toner cart. went out at the same time. I bought new cart. and still have th error message.
  • Anilmishra Apr 02, 2008
    i have same problem.
    first message showed - yellow catrage replace
    then i replace yellow catrage - then it is showoing toner left end cyan.
    really i m too much upset for this printer. now have to print some urgent documents but i can not.....
    please reply for solution asap.
    thanks
    anil
    Dubai
  • Anonymous Sep 13, 2008
    i HAVE THE SAME PROBLEM. i CHANGED THE BLACK TONER, AND NOW IT KEEPS SAYING TO CHANGE ANOTHER EVEN THOUGH THEY ARE NOT EMPTY. I CANNOT CYCLE THE CARTRIDGE HOLDER TO THE CARTRIDGE THAT IT SAYS TO REPLACE.
  • Anonymous Mar 24, 2014
    black cartage inserted but doesn't recognize it
    black cartage inserted but it says it is missing
Really Magicolor 2430DL is a very worst printer in this world.
within 2 months drum cartridge finish - no other printer like this type of option - like black, color & durm cartridge.
I will recommend - not to go for the thirdclass cartridge. go for only HP.
thanks
anil - dubai
Posted on May 13, 2008
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Nov 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
I put the cartridge in per instructions, but printer still says ''caution not installed toner check m toner''
Remove the cartridge -- is there any clear tape or cardboard "spacer" that should be removed from a brand-new cartridge?
Re-insert it. There should be a "click" or a "clunk" as it settles into its position.
Jan 07, 2010 | Konica Minolta magicolor 2430 DL Laser...
The toner life ended and then we got a refill. Earlier on refill, It was working fine, But this time it still says , TONER life end, replace toner. We tried loading 2 different refilled toners and cleaned...
we can refil toner many times but we should reset cartage, while we refiling toner to open cartage we should sides white rings middle plastick flate white plate make adownof cartage it is first methode. when we put reffiling cartage put on printer and do on at that time we push cartage right side pointo re set. look on www.brother.com
Nov 05, 2009 | Brother MFC-7820N Printer
Konica minolta 2530 dl Replaced black cartridge now says others not installed and "cannot rotate cartridges"
Clean toner chip reader, remove OPC drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it.
Jul 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
When i turn on my printer theres a message appear toner low
in your cartage have green cheap or fuse these are reseter. the are aviable in market .change it . then your printer can work. when are u getting tonner low. recently u shuld fill cartage. i think you get empty message. just reseting cartage by new reseter than u can change old reseter. u can 100% solve your problem thanks
Jun 19, 2009 | Samsung SCX 4521F All-In-One Laser Printer
After replacing black toner cartridge printer displays Drum Low
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
May 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta 2430 DL Xtoner not installed
Check the toner contacts in the printer, you may find one either dirty , bent or broken.
May 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
Toner Empty Message won't go off
check that the toner is inserted correctly, reboot print.
Aug 27, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
239 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
