My Bosh washing machine has excessive vibration according the the level i put on the top of the washer it is level, but still seems to walk accross the floor on the final spin cycle.
  • 3,600 Answers
It may be level but if the feet are not adjusted to be tight to the floor this will cause it to walk so try adjusting the feet then lock the locking nut I am sure you will find 2 that are not adjusted tight enough.
Posted on Feb 05, 2010
Why does it vibrate excessively, even empty?
It's probably 'out of balance'
Many machines have adjustable feet to take up any uneveness on the floor. If one or more of the feet are out of adjustment it allows the machine to 'rock' .. causing the vibration.
You want your machine to be as level as possible. Try putting a bit of cardboard underneath one or more of the feet to identify which foot needs adjusting
Nov 05, 2015 | Maytag Washing Machines
Can the washer be adjusted for excessive vibration?
All washers have to be level if you have excessive vibration then adjust from the bottom. i usually take a level and check from the top. If that dosent work let me know. You might have a different problem Hope it helps
Jan 17, 2011 | Kenmore Front Load Washer
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Excessive vibration since moving--not before
is the place you moved the washing machine level are the legs level if so you have a blocked sump
Jun 24, 2009 | Washing Machines
Excessive vibration on spin cycle.
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete or tile), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. One simple option to consider is to provide dampening of the vibrations. This can be done very simply as this one fellow demonstrates. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
Mar 12, 2009 | Bosch Washing Machines
Excessive vibration in spin cycle
Be sure the washer is on a solid surface, no plywood or skid platforms. Then be sure to lock in the front levelling legs.
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Admiral AW20 Top load washing machine
Dear Friend,
ngfam1 here for you!
I am happy to be of assistance!
Have someone help you to level the machine using a spirit level on top of the washer and adjust the legs up or down accordingly!
Other wise you need factory service!
If your not sure what you are doing stop... and call service!!!!!!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Please give me a good rating here in fixya.com before you sign out!
Aug 06, 2008 | Admiral AW22 Top Load Washer
Vibration
just because the level shows it is doesn't mean it really is. check the pedestal first. make sure it is level and all legs are tight and there is no wiggle. next do the same for the machine once it is put back on the base.
Sep 18, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Nov 08, 2006 | Maytag MAV4755A Top Load Washer
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
