Question about Canon BubbleJet i550 InkJet Printer
Changed the black ink cartridge yesterday and it won't print. The paper goes through, but there is no print on it.
    Problem Solver:
  • 10 Answers
The problem could be that you would not have properly installed the Cartridge into the Printer. Please remove the Cartridge, clean it with a Plain cloth and reinstall it again. Don't forget to check if the cartridge is installed correctly before you turn on the Printer. Once you do this process, try to print your document. Hope this time the Print will come. Else the Flexi PCB, which connects the Cartridge holder & the Processor board of your printer could be damaged. In that case you may have to take your printer to a authorized service station for servicing the Printer.
Posted on Feb 05, 2010
HPS 6500 all-in-one won't print
uh,faulty ink carterige, buy another one & don't forget to remove the clear tape seal..on the carteridge
Feb 09, 2013 | Office Equipment & Supplies
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
Black ink won't print and I just changed the ink
Try using the photo paper option instead of the plain paper option.
I was using plain paper but, selecting the plain paper option...I could barely read the print. The photo paper option worked great!
Hope it helps!
Nov 14, 2011 | Brother MFC 6490CW InkJet Printer
I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
Thus, no BLACK ink reaches the paper.
Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
The machine won't print. It won't feed paper, The
Your machine needs to be serviced.
replace the cartridge with the original one.
it can not print if one cartridge is missing or not original.
Jul 12, 2011 | Canon Office Equipment & Supplies
Won't print black, prints every other colour ok
1. try to cleaning head
2. remove the black cartridge only, (if it doesn,t changed after you cleaned head)
3. provide some warm/hot water on a bowl or plate.
4. enter the HEAD of black cartridge in to hot water. soak with depth about 2mm up to 5mm. while you see the ink is come out....
5. after the black ink has come out. pat dry with a paper towels/tissue.
6. replace the cartridge in to printer.
7. cleaning head again and print test page
good luck....
Jun 19, 2011 | Canon Pixma MP500 All-In-One InkJet...
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Black cartridge not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Jan 15, 2008 | Lexmark X75 All-In-One InkJet Printer
Canon BubbleJet i550 InkJet Printer Logo
old marine
old marine
