Water - Audio Players & Recorders
  • 863 Answers
No help for you, cause your fu.k.d. Water and electronics don't mix. Quit stressing over it and throw the thing out and get you a new one.
Posted on Feb 05, 2010
Water heater
Most instant-on tankless water heaters require at least 10 psi of water pressure to start the heating process. The flow of water determines how hot the water will be, within the heating range. An electric 110 volts heater will increase the water temperature about 25 degrees F. A gas water heater will increase the water temperature about 45 degrees F.
Too much flow will not allow the water time to heat. Too little flow will not allow the heating system to work. Each heater must have the outflow water flow adjusted for the best heating outcomes. The best way to find the ideal flow is to turn the hot water facet on and adjust it (open or close) until the water reaches the balance of producing hot water.
Apr 25, 2016 | Water Water Heaters
No hot water , no heater
No Hot Water - Electric Water Heater Troubleshooting
www.whirlpoolwaterheaters.com/owner-center/.../no-hot-water/
Whirlpool's video explaining potential reasons your water heater is not working ... Troubleshooting and Repair · No Hot Water (Video) · Replacing a Heating ...
Electric Water Heater Repair and Troubleshooting ' Whirlpool
www.whirlpoolwaterheaters.com/owner.../troubleshooting-repair/
Troubleshooting and Repair of a Standard Electric Water Heater. No Hot Water ... Not getting power is a common reason new water heaters don't work.
Troubleshooting Electric Water Heaters in MINUTES ~ Step ...
? 7:01
https://www.youtube.com/watch?v=SlyStHM9Nr0
Oct 4, 2013 - Uploaded by electronicsNmore
My tenant has a electric 30 gallon water tank. cimarron by Reheem. model ... So if u notice your water is overly hot and then notice no hot water ...
Dec 26, 2015 | Water Water Heaters
It will not steam. We put in a solution of vinegar and 2 parts water from a pitcher that filters water. Will this be considered distilled water or is distilled water critical?
Distilled water and filtered water are not the same. Distilled water is water that has been boiled then condensed so that most of the impurities that cause water hardness (Sodium, Calcium, etc.) have been removed. Filtering does not remove these which is why your iron will clog up much quicker. Same applies to your car battery, distilled water only! To clean it mix "Lime Away" with water about 1/4 cup with water every 6 months or so, then rinse with clean water a few times to get rid of the green color, steam until it comes out clear again..
Mar 10, 2015 | Rowenta IS9100 1550W Precision Valet...
Why my refrigerator is leaking water from the top where the water filter is located?
Shut off water supply valve. Relieve water pressure by dispensing water. Unscrew water filter. Examine to see if the gasket is damaged or if filter was loose and just needed tightening. Or simply replace water filter with the correct water filter that your GE refrigerator calls for.
Jul 19, 2014 | GE Refrigerators
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
Does not have much hot water gets cold fast
tank water heater? if so its because the water is much colder this time of year. water heater has to work harder to heat 40deg. water than 70deg. water in the summer. That also means as you use the hot water from the tank its replaced with very cold water. Causing you to have less hot water. Either get a larger water heater. Or even better go tankless and have never ending hot water and save money at the same time.
Jan 09, 2013 | Rheem 50 GAL FVR Propane Gas Water Heater...
I have a 1999 Ford SHO that needs a new waterpump. I need to know how to replace it and where I can get a schematic of it. Do I need a special tool kit to do it? I'd also like to know where I can get the...
www.autozone.com
They can get all the parts. They also provide haynes repair manuals, any special tools (probably not required for this vehicle) and any special disassembly instructions.
I hope this helps.
Mar 11, 2010 | 2001 Ford Taurus
Runs out of hot water
I wonder if you have this problem below caused by a drop in water pressure from someone flushing a toilet or a washing machine. I would call the company to remedy this issue.
17. What is a cold water sandwich effect? The term “cold water sandwich effect” is a term that is used to describe the introduction of cold water into the hot water supply line during frequent on/off operation of an instantaneous water heater. The cold water sandwich effect, when present, appears as a momentary drop in hot water temperature as it is discharged from a hot water supply outlet (i.e. shower, tub, or faucet). This phenomenon is present in the operation of all instantaneous, tankless style, water heaters, but is minimized with the high tech design of Rinnai water heaters.
The technology built into the Rinnai water heaters is designed to minimize the cold water sandwich effect. Rinnai water heaters are microprocessor controlled and when water flow through them ceases, they remain in a “ready to fire state” for approximately 1 minute. If water flow through a Rinnai water heater begins within the first minute following water flow stoppage, the water heater will fire back up within 1 to 2 seconds. This minimizes the cold water sandwich effect that would otherwise be experienced with a low tech tankless water heater. It should be noted that the cold water sandwich effect cannot be removed completely from tankless style water heaters. The safety standards developed to insure the safe operation of water heaters require a delay in the ignition sequence of all gas water heaters.
While the cold water sandwich effect cannot be completely eliminated from standard plumbing systems, it can be eliminated from plumbing systems that have a supply and return hot water circulating system. Rinnai has developed 2 methods to eliminate the cold water sandwich effect in residential hot water circulating systems.
The first (and preferred) method to remove the cold water sandwich from circulating systems utilizes a small electric tank water heater (powered up) that is used with a dual purpose. The small water heater acts as a mixing tank to eliminate the cold water sandwich effect from the Rinnai water heater and it uses its electric heating element to offset the heat losses from the hot water circulating system.
The second method to remove the cold water sandwich from circulating systems utilizes a small 2 to 6 gallon storage tank installed on the hot water outlet of the Rinnai water heater. This tank acts as a mixing tank to blend the cold water sandwich with hot water and eliminating its effect at fixtures.
Mar 11, 2009 | Rinnai Water Heaters
 Grubhead
Grubhead
