Question about AEG Ovens
AEG Competence Oven not working
The element on our AEG Competence 3210BU-w double oven went so I have replaced it but the oven is still not heating up. The fan comes on when the oven is switched on but no light to indicate that the oven is heating up.The top oven and grill are both still working. Any ideas?
  • AEG Master
  • 3,463 Answers
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Posted on Feb 05, 2010
I have an AEG Competence Single oven model B2100-1-w The oven is not reaching or holding temperature I have noticed the fan is not spinning
Hi steve sounds like your fan motor is faulty they are not very powerful any resistance in the bearings can stop it starting. oiling the bearings wont help you need to replace the motor also it will have damaged the element no air circulating it will of overheated. an overheated element usually lasts till xmas morning.
Nov 09, 2010 | AEG U3100-4 Electric Double Oven
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
Oven is AEG Competence, single oven, fan assisted, 4 yrs old. Oven doesn't heat. Light ok, automatic cooking settings not switched on, grill working
If the fan is working o/k, then you need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
This should solve the prob.
Please leave feed back.
Thankyou.
Jan 06, 2010 | AEG Ovens
Heat element is not coming on!
It is entirely possible that while cleaning the oven you may have inadvertantly bumped the element enough to cause it's connection to come loose enough not to work. With the power unplugged, wiggle the element where the connection is made inside the oven. If this does not work it is possible the element has 'gone bad'. Sometimes this happens from various causes and replacements are available from the manufacturer
Dec 04, 2009 | AEG Ovens
Aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Jan 27, 2009 | AEG B2100-4 Electric Single Oven
AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 29, 2008 | AEG D5701-4 Electric Double Oven
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Ovens Logo
1,391 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
