Question about Whirlpool 20.9 cu. ft. Top Freezer Refrigerator ET21PKXG
Water in bottom of the fridge. I figured the
Water accumulates in the bottom of the fridge. I figured the defrost drain is clogged but I cant get to it. I guess this assembly is behind the cover (that covers the fan) which is in the freezer compartment but I'm afraid to pry it off (might break it?). The only tube running down the back is the ice make lines (no defrost dran tube) so it must be buried? Whats the best way to remove this cover and unclogged the drain line. (model ET1CHK/ET1CHM)
  • guypiasecki Feb 05, 2010
    OK... I now know way more than I ever wanted to know about my refrigerator. I first removed the screws (about six or seven of them) from the cardboard cover in the back and sure enough the water drain pan was bone dry. So it had to be a clog…but where is that darned drain? Well I found the following link helpful as it gave me a clue as where to look:
    http://www.applianceaid.com/frig_leaking...
    And sure enough, Whirlpool hides the drain hole behind the false back in the freezer compartment on this model. First you have to remove the wire shelf and bottom shelf plate within the freezer compartment. The drain hose must be embedded in the body cavity as its not visible or accessible from the back. To remove the plastic bottom shelf tray, remove two screws and it should lift out as it simply butts up against the false back. Once the bottom is out you can see at the bottom (at the back), a metal tray or gutter for the water to run down when the coils behind the false back defrosts. It may be hard to see, but near the middle of this metal gutter is a hole. That's the drain hole! Mine was covered up with ice so it was hard to find/see. I also ended up removing the ice maker and false back (two screws in the back) to get at the ice build up easier. You have to lift up on the back to remove it as the cover is recessed into the bottom of the freezer compartment. I then tediously use my wife's hair dryer to melt the ice in the tray and drain hole. What took so long is that the ice went down into the drain hole quite a ways (at least an inch) before it started draining again. Then you have the joy of reassembling everything and hopefully you had moved your beer to an alternate cold spot so you can now enjoy a cold one.
  • 4,793 Answers
Copper wire is best with a bit of cloth to pull thru
Posted on Feb 06, 2010
Water in bottom of fridge inside...cant find drain holemodel rf18hfenbww
It is not designed to have water in bottom of fridge so there is no drain hole there. Sounds like you have a stopped defrost drain which is in freezer. When this is clogged with Ice, water from defrosting has no where to go but thru air flow holes from freezer to refrigerator. If this is in fact your problem, you will most likely observe a sheet of ice in bottom of freezer.
Aug 25, 2017 | Refrigerators
Why do water accumulate at the bottom of my fridge under the vegetable tray?
If your refrigerator is frost-free, the water accumulates during the defrost cycle and should drain through a tube at the bottom into the evaporator pan underneath. The tube may be clogged or broken.
Dec 18, 2014 | Refrigerators
Water accumulates and freezes on bottom of freezer.
Orange glow is defrost heater and that is normal. Crackling sound is heater heating up area around it, normal. Water and ice build up in the bottom is due to a clogged defrost drain.
Sep 01, 2012 | Refrigerators
Water accumulates under vegetable bin (bottom of refrigerator) every couple of days
If this is an older style top mount refrigerator than most likely the drain is clogged causing the water to leak into the fridge during the defrost process. What's the model number?
Jul 06, 2011 | Refrigerators
Water is accumulating & freezing @ bottom of freezer ice maker has been removed water to fridge has been turned off still, water coming from somewhere & freezing
This is what it sounds like to me. There is a drain hole for the defrost water to drain down to the "drip pan" If that hole in the drain pan is clogged. Then when the defrost system melts away the frost in the cooling coils. Every 6 or 8 hours. The water will accumulate in the bottom of the freezer compartment and turn into ice. This is a very common problem.
The solution.
Put the food in the freezer and fridge into coolers and pack with Ice. Get the 99 cent coolers at the supermarket and buy some Ice there too.
Shut the fridge down and open the freezer door. chop out the Ice in the bottom of the freezer compartment, but not in the drain area directly below the coils. that will be hard to get to and you may damage the fridge if you just chop away.
To speed up the process, get some hot water in a glass and pour it into the area below the coils
(that should be a solid block of Ice as well). If you cant get to this easily, just wait for the fridge to thaw out naturally.
After it has thawed out, you should be able to locate the drain tube in the bottom of the small tray
below the coils. Stick a flexible piece of wire, or pipe cleaner or something of the sort into it to completely unclog it. So when you pour water into that tray, it immediately drains out completely.
into the "drain pan" located below the freezer compartment in the base of the fridge.
I hope this helps,
Best Regards,
Mark
Dec 30, 2010 | Maytag MSD2756GES Side by Side...
I have water in my refrigerator on the shelves and in some areas it is freezing?
Could be a clogged condensate drain. Since you did not give a model #, I will assume this has the freezer on top. When it goes into defrost, the water cannot go down the drain hose to the drain pan and accumulates as ice in the freezer, below the bottom liner and may drip into the fridge. Empty the freezer and open the fridge door. The open fridge door can help thaw the drain. Remove the screws holding the bottom of the freezer liner and remove the liner. If there is ice below it, the drain is clogged. Remove as much as possible by hand and then use a hair dryer to carefully melt the ice at the back of the freezer. Blot up any water from the melted ice and concentrate on clearing the 1/2" hole in the center back. That is the drain. When you think the drain is clear, check it with a large glass of hot water. This can be take some time. When done, reassemble, but also make sure the fridge is tilted to the back by adjusting the legs at the front bottom corners of the fridge. You may have to take the grill off the bottom of the fridge to do this. The legs screw down to lengthen them. Adjust them far enough down that the fridge door swings shut by itself. This will help the water down the drain before the fridge comes out of defrost, starts cooling and freezes it in the drain hose.
Mar 03, 2010 | Whirlpool Refrigerators
Leeking water inside fridge from top
Defrost drain is clogged. This accessable thru the back wall of the freezer. Also depending on your model some also have removable Bottom floors of freezer that also get ice accumulation. When the defrost drain gets clogged water from the defrost cycle has no where to go so it stays and accumulates ice till eventually it leaks into the fresh food section. Clear the drain completly and you will have no more problems.
Feb 02, 2010 | Freezers
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Refrigerators Logo
571 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
