Question about MSI PM8M-V Motherboard
Front usb motherboard ports don't work rear ok. os/windows 7
You've probably connected the pins wrong. You should find the manual and see how your front USB ports must be connected
Posted on Feb 05, 2010
Blue screen when usb plugged in to new board old xp home
1.) Ensure XP is updated with latest device drivers
2.) Ensure latest chipset & motherboard drivers are installed
3.) Check USB drive, and USB port
4.) Boot up with any Linux OS Boot up disk and check if USB is working
5.) Install Windows 7 in case new drivers not available on XP
Feb 26, 2013 | Computers & Internet
Front pannel usb connection for Motherboard (945GZM775SE)
Ok, what about the front panel usb connection??
If they don't work, you can always plug in a usb adapter into one that does work to get more usb ports.
May 16, 2012 | Biostar 945GZ-SE Micro Socket 775...
My usb ports do not work. Memory stick works on other computers but not my desktop. Help!
Do any other devices work on any of your USB ports on the desktops? Does the memory stick work with a port that works for another device?
If all of the ports fail, check the Device Manager (for Windows OS) - you may have a driver issue. This is reached through the Control Panel (under Hardware or System). The exact titles will depend on the version of the OS.
When you scroll through the list to the USB controllers, look for a triangle with a red x or a yellow triangle. The right click (or double-left click) and try to update your driver or roll back the driver to an older version that worked.
If only a few ports fail, then are you dealing with the front ports or the rear ports? If the front ports (case), then you might want to check if the header cable is fully connected to both the case and the motherboard. This requires opening the case with the appropriate care.
Unfortunately, some new USB devices pull too much power through the port and can burn them out. (Those that charge on the computer are the most likely culprit.) If you have a few working ports, get a USB hub that is self-powered. (Get a good one or only use the AC adapter when there are more than 4 devices connected to the hub.)
I hope this helps.
Jul 26, 2011 | Computers & Internet
I have loaded USB 2.0 Driver but System could not detect that USB 2.0 Port when I connect USB 2.0 device to all six USB Port. I am having DG31PR Motherboard. I checked in BIOS setup. High speed port enable...
You have not mention what Operating system is on your PC.
For Windows OS XP, you just have to install at least XP Service Pack 2 or higher... and the USB 2.0 ports will function. For Vista & Win 7 OS, the USB 2.0 drivers is in the Operating System when you install Windows.
Hope it helps.
Jul 13, 2011 | Intel DG31PR Motherboard
My USB ports won't work on my gigabyte MA69VM-S2 mobo with win7
Unlikely to be issues with the OS. Have you recently upgraded to Win 7 from Vista or XP? and did the USB ports work with this OS?
Do ALL usb ports fail or is it just one or two and are these the front USB's or rear USBs?
Dec 29, 2010 | Gigabyte GA-MA69VM-S2 (rev. 1.0)...
We have recently purchased an Intel I7 processor and installed it into the ASUS P6T motherboard. We have also installed Windows 7 OEM builders operating system (not an upgrade version over windows XT). The...
Run "Windows Update", to see if it will find updated device-drivers for the specific USB hardware on the motherboard.
Access the ASUS web-site, and search for 'P6T', and search for USB device-drivers for Windows 7 -- if none are found, try the device-drivers for Windows Vista.
Jan 22, 2010 | ASUS P6T7 WS Supercomputer Core i7 / Intel...
Problems with the front usb ports
Hello!
I see many comp. with problem on front usb port. In some case USB port isn´t right plug in motherboard, or is everything OK but they don´t recognize USB stick.
Only one, don´t lose you time with that, don´t use that USB port.
Oct 30, 2009 | Antec Computers & Internet
Usb not working
Check that all the USB ports are turned on in the BIOS setup.
Apr 02, 2009 | PC Chips (M925G) Motherboard
Front Side USN dows not work in ASUS M2N MX SE
The front side port may be a "low power" USB port, it may be possible to "power" this if there is the capacity to connect a power cable to the front panel USB adapter, or there may be an aux power socket to plug into on the motherboard.
Nov 04, 2007 | ASUS M2N-MX Motherboard
Front side USB port is not working
On some computers the front usb ports are like a usb hub, they don't have enough power to power up a hard drive.
MSI PM8M-V Motherboard Logo
507 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
