Question about Dyson CRO1 Front Load Washer
Machine says it is flooding - Dyson CRO1 Front Load Washer
F 11 flooding
Posted on Nov 06, 2010
My machine seems to be stuck on a drain cycle
Sounds like your 'anti flood' system is activated. This happens when a leak fills the drip tray on the base of the machine, and a anti flood float switch senses water in the tray. Leaks can come from several sources - loose pipes, leaking door gaskets - even opening the door while the machine is hot! i.e. to add an extra item after the machine has started, for example. ISOLATE THE POWER and examine the base tray, if its a free standing machine tip the machine back at an angle (The Hemlich manoeuvre for Dishwashers lol) and the water will flood out - if built in, remove the lower front panel. Once the water is removed, the machine should start - but if the problem occurs, the leak is still there. Zanussi machines are tricky - you'll probably need an engineer to sort it out - expect not much change out of £100. Cheers!
Oct 16, 2015 | Zanussi 18 in. DCS12W Free-standing...
What is the flood switch on a dw60cdx1
We had an F1 error with our F&P dish draw,Isolated the power to machine, then I removed the drawer & cover from the flood sensor, Dried water with towel & used hairdryer. Power cycled the unit & has fixed the problem.
Had used a different powder & believe that it created more foam that caused the machine to flood slightly
Jul 03, 2014 | Fisher and Paykel DS602 Dishwasher
Anti flooding on aeg 64840
Problem was answered earlier. Please check the water level sensor, check the line , remove and reset. Also check for blocks in the INLET and DRAIN filters.
Jan 20, 2013 | AEG Washing Machines
Anti flood stuck on
Turn the water back on at the wall.
Aug 20, 2012 | Dishwashers
We have a 5 year old front load whirlpool duet washer that leaks & floods and has since we bought it. We had it replaced within a year of purchase, but it continues to leak & flood even with a new...
Due to the fact that you have had two different machines with the same problem seems to rule out a problem with the machine itself. Inspect the drain system that the machine discharges into. I have seen washers that have pumps which can overwhelm the house drain--the cure was to increase the machine's drain spout outer diameter with duct tape until it was a tight fit into the house drain. This prevented water overflowing from that point. The better cure would be to increase the drain pipe size, but that can get pretty expensive. Hope this helps!
Nov 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
OVERFILLED AND FLOODED HOUSE
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
May 25, 2009 | General Electric WCSR2090D Top Load Washer
Hotpoint Ultima WD71 - floods on drying programme
you may have a hose loose or holed at the inside rear of the machine.
Jan 04, 2009 | Hotpoint Ultima WD72 Front Load...
Water sometimes does not shut off. flooded twice. happens intermittently.
If when the machine is flooding if you turn off power to the machine and it continues to fill: replace water inlet valve. If flooding water stops filling when power is interupted: clean out the end of the water level switch tube where it connects to the outer wash tub.
Sep 17, 2008 | GE WHRE5260E Top Load Washer
Indesit washing machine flooding when filling
if you washed coins, it is quite possible you have breached outer tub with them.
Sep 04, 2008 | Washing Machines
Dyson CRO1 Front Load Washer Logo
70 people viewed this question
Top Dyson Washing Machines Experts
Gerry Harvey
Gerry Harvey
paul
paul
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
