Question about Ruud Matching Split Air Conditioner
Need Fan Motor and Capacitor
Where is the least expensive place to buy a fan motor and fan motor capacitor for a Ruud Achiever Model UPKA-035JAZ
  • 3,600 Answers
The best place is from rudd the cheep price will leave a bad taste in your mouth long after you replace it with after market parts. And the cost will be double. My experience in buying aftermarket parts almost cost me my business when the parts failed and I had to replace for free. Once you plug in a electrical part you own it. Take my advise don't save money on a aftermarket part unless you want to pay for it's repair twice. How ever if you still want to do this look in the yellow pages in your phone book in your town for any motor re-winder and they can get you one. or look on the net with your zip code for the closest rewinder.
Posted on Feb 05, 2010
Testimonial: "This was very helpful information. Before I received the feeback, I had already ordered the OEM parts. The OEM parts were less expensive too. Thanks"
Hello all My Rudd AC unit will start and run find maybe for 10 minutes and cool air then the fan outside will stop and unit hums or hisses and blows hot air inside vents. I changed out Thermostat and Run...
Welcome to the world of Ruud! Ok James heres the deal. It sounds like the condenser fan motor has failed. Its not a repairable item but the motor is not too expensive. Disconnect the main power at the fuse block on the side of your house next to your a/c. Remove the screws that hold the top fan section and carefully turn the fan/panel assembly over taking care not to stress the wires. Determine how the fan is mounted (probably 4 screws) and go find your new motor. Both Rheem and Ruud use the same motor mounting. Most a/c supply houses have a motor that will fit or go to graingers. Make sure you get a matching run capacitor for that motor. It will have separate wires and not share any wiring with the old capacitor. The old capacitor will have to stay in place since it is also connected to the compressor. The old motor will have 3 wires and the new one 4 (2 brown for the capacitor and 2 others to put on the contactor that the compressor wires go to). If its a heat pump it could be a board and youll need help. good luck
Aug 15, 2013 | Ruud UBHC Air Conditioner
Upka 035jaz
match original loosen mounting bracket if necessary to read its mfd. rating.
Jul 03, 2013 | Ruud UAKA042 Air Conditioner
Ruud achiever 10 inside blower motor burning
Check fan cage to make sure it turns freely. Check voltage to IFM make sure it is correct for the application. Make sure the motor turns the fan cage in the correct direction. IFM will have high and low speed make sure when you change from fan on to auto that the motor changes speed. If you have an amp draw meter check to see when running the motor pulls the amp load it is rated for. Recheck all wiring.
Feb 29, 2012 | Ruud Matching Split Air Conditioner
I have a 15-year old Ruud Achiever 10 A/C unit outside that has blown a second set of fuses in just a month. The fuses are in the box on the wall adjacent to the unit. What may be causing the fuses to...
A BAD RUN CAPACITOR INSIDE THE CONDENSING UNIT ?.SEARCH YOUR AREA FOR FREE CAPACITOR TESTING.OR LOCAL ELECTRIC MOTOR REPAIR.. CHECK THAT FAN SPINS FREE, IF NOT, IT CAN BE OILED .. SEARCH POST ON OILING FAN MOTORS
Jul 26, 2011 | Ruud Matching Split Air Conditioner
Air conditioner fan will not turn on outside. Rudd model# UPKA-025JAZ
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. bobicehouse_41.jpg
If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor.
Jul 22, 2011 | Ruud Matching Split Air Conditioner
Fan not blowing outside on ruud achiever series
try starting the unit and with something that can fit tru the grill try spinning the fan blade in the direction that it supposed to turn check either direction just to be sure, if the fan starts then replace capacitor. if it is stuck then replace capacitor and motor. there could be other causes for the fan not turning but this are the main causes. picture one show a dual capacitor used for compressor and fan bottom picture shows two capacitors the smaller one is for the fan. best of luck and always follow safety guidelines when working with high voltage capacitors can still hold a substantial electrical charge even when all power is off.
May 29, 2011 | Heating & Cooling
I have a RUDD Achiever 11. The outside fan only intermittently runs and seems to quit in the evening (overtime for the air condo techs). It won't start again until the morning but when it runs, it blows...
Two possible problems here.
1. you have a bad condenser fan motor. average cost $140.00 for the part plus installation if you can't do it. just buy the motor you most likely will be able to use the existing fan blades.
2. you have a bad run capacitor on that fan. avg cost $5.00 - $35.00 plus installation
In my opinion if you're handy and safe with electicity save some money, if not have it done.
check out grainger.com for the parts they're very reasonable. for the fan you'll need to get specs from the defective unit like amp. voltage rpm. its all on the unit itself. for the run capacitor you'll need the same. all the info u need is on the parts. search the site for run capacitor or condenser fan motor.
good luck hope this helps
Jul 15, 2010 | Ruud UBHC Air Conditioner
Have a Ruud Achiever Model number UAKA-037JAZ that won't run since yesterday. When the air kicks on it simply makes a buzzing noise and the fan doesn't spin. Can anyone help?
try spinning by hand when the unit make the buzzing sound. to see if the capacitor is bad. If the fan runs replace the cap. If not motor probably is bad. See if it spins freely. this is a good starting place. need to check if the buzzing is the contactor and there is no power to the condensor. The contactor will buzz even though the main breaker is off or tripped
Aug 10, 2009 | Ruud UAKA037 Air Conditioner
Ruud Achiever 10, outside Fan wont spin unless I help it.
The part you are talking about is called a capacitor. They come in various voltages and ratings. The best thing to do would be to find the rating tag on the motor, and look for the capacitor rating. There are many, many different sizes and types, so it is best to consult a proffesional before attempting to replace it on your own.
Jul 06, 2009 | Ruud UBHC Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Ruud Matching Split Air Conditioner Logo
615 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
