Can a US VCR be made to play PAL format videos?
I recently got a code that gave access to a hidden menu on our DVD player and the ability to make it all region. Can you do the same for VCR's?
We have three old VCR's.
  • BigRach101 Nov 08, 2008
    I'm buying "Ally McBeal Season 4" VHS and I dunno if video tapes from the UK are picky, but I'm also getting "Ally McBeal Season 5" and that's a DVD. Can I have the code please? I don't understand this international movie formatting stuff....
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
VCR's cannot be open region enabled. I would try and play the PAL region video if you havent already just to make sure it works. I dont think videos are region sensative..
Posted on Feb 20, 2008
My lg video is only playing black and white films, the tv is still playing colour. It used to play colour videos at one time
try changing the colour options in the menu.
they are PAL,SECAM and others.try all of them till you find the one that matches your videos
Feb 14, 2011 | LG V271 DVD Player/VCR
It's showing the video in a split, black and white screen
could be a pal/ntsc region code problem, either the menu setting is pal and your playing a ntsc region coded dvd or the menu is correctly set at ntsc and the dvd is pal that you are trying to play
Dave
Dec 27, 2010 | Initial IDM-1210 Portable DVD Player
Disc Error: My question is a result of a recent problem that I have been having with your product and recorded DVDs. On certain movies, I have been able to play them with absolutely no difficulty. However...
some older dvd players dont play dvdrs very well, but most wont play dvd in pal format only ntsc some movies are recorded in pal, you can change format if you are using nero on the last stage wher you click burn choose ntsc
Apr 13, 2010 | Emerson EWD2204 DVD Player/VCR
I have converted some NTSC vhs to PAL dvd, when i play them on my LG DVD player, it says disc error
U must copy NTSC to NTSC.PAL to PAL.Check ur DVD recorder/VCR combo menu set up regions auto, if it have it.Will play all regions DVD discs.
Mar 26, 2010 | LG RC897T DVD Recorder/VCR Combo
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Unable to play a DVD movie
Most probably the TV system is not compatible.
This VCR/DVD uses NTSC formate. Is the DVD in PAL formate. Also the Region code can be different. This DVD palys DVD-Disks with regional code 1 or All.
Dec 09, 2008 | GoVideo DVR4300 DVD Player/VCR
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
Playing PAL system dvds
Turn unit power on
with dvd draw closed and with no disc
press 9735
hidden menu appears
select REGION 0
exit setup
for multi zone compatibility and enjoy...
Sep 21, 2007 | Jwin JD-VD149 DVD Player
NTSC to PAL
You have to buy first a VHS player that can play NTSC, might not be available locally in Ireland so you have to probably buy online (US). The DVD recorder is fairly comnon nowadays and all of them are capable of recording and playing NTSC and PAL. You can then connect the AV out of VHS player to the AV In of the recorder. Or you can use a VHS-DVD combi. You can google in UK, here is an example: Toshiba RD-XV45, according to the specs, it can play NTSC on the VHS and you can record to DVD on any format that yoou want You can go to this link to view other product: http://audiovisual.kelkoo.co.uk/b/a/sbs/100304323/16875665.html My father died of cancer 6 years ago and I am also transferring the Hi-8 videos to digital format using PC.
May 23, 2007 | Samsung SV5000W VHS VCR
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
