Question about IBM ThinkPad A31 Notebook
Yesterday I reinstalled my windows on my laptop which has 20 gb hard disk, i created two partition drive c (5 gb) and drive d (15 gb) and installed successfully. after that i put my pen drive and copied some amount of data to c drive. in between the copy operation electric power went. after 2 hours when electricity came, i started the laptop again to check if everything is fine but laptop does not boot up it just shows a blank screen. I tried to boot from cd rom and I see the same blank screen. please note my laptop has no power backup since its battery has expired. Please help me to figure out this problem
  • 3,600 Answers
You killed the laptop with out a UPS and you get a power surge with a dead battery them laptop takes the surge and kills the computer. You can remove the battery and unplug the power supply and hold the power button down for a minute then plug the power back in without the battery and try pushing the power button to see if it comes on if it does your lucky. IF it does not put the battery back in and try again. if There is still no power you have killed the power converter or killed the computer.
Posted on Feb 05, 2010
I cannot partition all of my Seagate 3GB HDD.
If this hard disk came with your new computer or laptop then the hard drive may have a small 2nd restore partition. This partition is not for normal use, it is only used to fix your computer/laptop if you need to restore it back to the Out of the Box condition.
You can use Disk manager to wipe this restore partition and create a data 745.52Gb data partition. I would not recommend you do this as you need the keep this restore partition if something happens to destroy your Windows 7 operating system.
Mar 02, 2013 | Computers & Internet
Is it possible to partion System drive.?
If your C drive take up all the 250GB, and the used data is not up to 250 GB( I means there are some free space on your c drive) you could use other partition software to release some free space ( resize partition) then create new partition, with the help of partition software, it could apply the operation without re install OS.
Oct 23, 2012 | Microsoft Windows XP Professional SP3 Full...
How do i use my second partition of my hard drive? my laptop is a dell vostro 1088. It seems that my OS (C:) is full but i see that i have a new volume(F:) so how do i use that? Originally, my laptop...
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems. Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
hope this helps
Apr 23, 2011 | SIB 320GB 5400RPM 8MB Cache SATA Hard Disk...
If i erase my hard drive will it remove all traces of infections on my computer and can i install windows7 instead of reinstalling vista
Hello, Yes if you reformat your hard drive, it will remove any virus software that would be on it. Windows 7 have a recommended minimum pc configuration. Make your pc is up to those configurations.
  • 1 GHz processor (32- or 64-bit)
  • 1 GB of RAM (32-bit); 2 GB of RAM (64-bit)
  • 16 GB of available disk space (32-bit); 20 GB of available disk space (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Hope this helps
Jan 30, 2011 | Acer EXTENSA 54205038 COMPATIBLE LAPTOP...
Doesnt want to be read by the computer it lights up and instals drivers doesnt show up in my computer
Your external hard drive likely has no partitions so Windows has no drive to mount. Follow these steps to create and format a partition for your external hard drive.
1. Press Win+R to open the Run command.
2. Type "Control" into the dialog box.
3. Double-click Administrative Tools.
4. Double-click Computer Management.
5. Select Disk Management under Storage.
6. Find the 250 GB External Hard drive in the right pane.
7. Right click on the drive and select "Create new partition".
8. After the partition is created you will need to format the partition.
9. Format the partition as NTFS unless you plan on booting off the hard drive, in which case format the partition as FAT32. You can also create multiple partitions if you want.
10. Enter My Computer and you will now see your external hdd.
Good luck and thanks for using FixYa.
Dec 29, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
Windows 7 does not recognized it
Dec 27, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
I had new dell inspiron 1501 laptop with windows 7 os instaled in 350gb singel drive and i want to saparet two or more parteshens with out OS loss
if your hard disk is only 1 partition right now, reformatting the hard disk, then deleting the current partition and creating additional partitions is the way to do it. This means, you also have to reinstall Windows. if you do not want to reinstall Windows, look for programs like partition magic or the like that can allow you to create additional partitions, though, there are cases this may have issues later.
Sep 03, 2010 | Dell Inspiron® 1501 (N11157) PC Notebook
Recently i ordered a dell studio 14 laptop. they did not send me any copy or disc of the OS installed in it, i.e., Windows 7 Home Premium. however the entire 500 GB of hard disk space has been only in the...
Hello Sir,
You can create a Partition in your hard drive without affecting your OS. Just follow the process I've sent.
1.) Go to Start Menu and Type in search area Create and Format Hard Disk Partition.
2.)Open the Create and Format Hard Disk Partition.
3.)Now you can Select the C: and can Partition it with another new drive.
Thank You
Aug 09, 2010 | Dell Computers & Internet
Drives - size
Resizing partitions is easy with the right tools, and near impossible without them. You will want to first
get a good hard disk imaging program along with an external hard drive (some drives come with imaging software bundled with the drive) a few examples would be Norton Ghost, Acronis True Image, Dantz Retrospect, Powerquest Drive Image and so on. There are even some good freeware and Open Source alternatives. By imaging your c: drive to a USB external drive you can safely edit your hard drive partition tables and then put everything back with no reinstalling Windows or losing any data. You will need to have a bootable recovery CD on hand when it comes time to restore the image from the USB drive to your system drive. I would suggest that you first copy all files you want to keep from the d: e: and f: partitions to the c: partition, then image the c: partition by itself to external drive. Take note of the c: partition type I.E. FAT32 or NTFS. Make a bootable utility disk (Ultimate boot CD available from Filehippo.com for free) is one, an emergency boot floppy from Windows 98, ME, NT will work also. Boot with it and run FDISK to delete extended drive letters D E F and then their partitions and then delete the C: partition and finally create the C: partition with all available space and make it active. Replace the utility boot disk with the recovery boot cd, restart the computer and run the image recovery to restore everything back to your now 80gig system drive.
Jan 07, 2009 | Biostar NF325-A7 Motherboard
My hard disk
the 7GB is probably the first partition from previous installation. You will need to delete all partitions on drive and then format the drive, that is if all is backed up. once that is done you can create a few "new" partitions and install Windoze to the first partition. make sure to make that one active and/or primary. the other partition you can use for Data.
Jun 27, 2008 | MSI KM4M-L Motherboard
IBM ThinkPad A31 Notebook Logo
52 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
