Question about Exercise & Fitness
Service code reset on a 1400 lamar treadmill - Exercise & Fitness
I have a New Balance 1400. How do you do a hard reset on it?
In almost all treadmill error 1 denotes the speed sensor error.
In you case I suspect there is some variation in the alignment of the speed sensor. May it moved away from the magnet Which is fixed on the rotating wheel. Try to make it closer as much as it can, be sure not to keep a small distance .hope it will solve the problem.
If you wish to get some more details about treadmill repair and service then check the following link.
http://electro-medical.blogspot.com/
Sep 26, 2016 | New Balance 1400 Treadmill
What kind of lubricant does the Lamar L1400 use?
depend. YOu must read your instruction manual, and see if it is a) silicone or b) wax.
download from www.fitness.manualsonline.com
God bless you
Sep 27, 2013 | Startrac Fitness Products Lamar L1400...
Error code E-2 on Lamar, Ignite 1726 exercise bike
please follow this steps and fix it. God bless you
    • 1 Check the connections on both ends of the data cable to ensure they are secure and connected properly. The data cable runs from the back of the console to the flywheel assembly. The covers over the flywheel assembly may need to be removed to access the data cable connection. Verify that there are no bent pins in the cable connection by detaching the connection and visually verifying all pins are straight. Reconnect the cable connections, ensuring that the small latch on the connectors snap into place.
    • 2 Verify that there are no cuts, crimps or other damage to the cable. If the cable is damaged, replace the cable with a new, undamaged cable.
    • 3 Replace the console if there are no problems with the cable or the connections.
Dec 06, 2012 | Startrac Fitness Products Lamar L1400...
Lamar 1400 message "Perform Scheduled
My Lamar 1400 says" L 14 scheduled maintenance" and will not run.
Nov 02, 2010 | Startrac Fitness Products Lamar L1400...
I have a NB 1400 Treadmill that is shutting down and giving the E1 code in the display. I see that there is a solution that says it is a sensor code. What sensor and what is the solution to fix the...
The sensor is one that records the movement or speed of the belt, some machines are located next to the engine flywheel. and other off the front roller pulley on the left side exactly. physical form depends on the manufacturer and the only solution is to buy, where somewhere distributing or selling accessories for treadmills
Sep 08, 2010 | New Balance 1400 Treadmill
Treadmills doesnt run
check the cord or outlet, also check the brushes of the motor drive and as a last option check the control board motor (Diodes or mosfet etc.)
Dec 04, 2009 | Startrac Fitness Products Lamar L1300...
Perform Scheduled Maintenance
Contact clubhouse, overiding or attempting to change setting may cause more damage than good. Especially if you don't know what you are doing.
Jun 02, 2009 | Startrac Fitness Products Lamar L1400...
Lamar L1400 locked says it needs Maintenace
Press and hold for 6 seconds the UP buttons for Speed and Incline.
Then you're ready to run again!  YAY!
May 28, 2009 | Startrac Fitness Products Lamar L1400...
Exercise & Fitness Logo
78 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
