Question about Maytag Dryers
How do you get to the insides of the machine? Removing the front, door panel?
  • 3,600 Answers
You have to remove the bolts on the back of the machine and you have to remove the control head to get to it. since you did not post a model it's hard to say but you can look it up onthis web page if youhave the model number.
http://www.appliancepartspros.com/
Posted on Feb 05, 2010
I need to replace door seal on this machine but i dont know how to remove the front of the machine i have the top cover off
If it is Whirlpool / Maytag try parts diagrams at
www.whirlpoolparts.ca
Normal procedure to open front door panel on a front load.
1. Remove top cover.
2. Remove Control panel.
3. Remove bottom kick plate cover
4. You will see the door panel screws. Two on top corners and two on bottom corner.
5. Keep in mind, you have to remove the door lock (latch) from door panel before removing door panel.
Apr 25, 2015 | Washing Machines
My washer door will not open its a wd645 model i cant find the lever when i took lid off
Hi.
The door latch is probably broken. Emergency opening can be done accessing the door latch from the inside of the washer assembly.
Before attempting an emergency opening, disconnect power cord and empty water inside the machine through the filter located at the bottom front side of the machine.
After removing water connect back the machine and try opening again.
If that does not work, then the machine must be disassembled. Most models have an emergency cable located on the inside of the door latch. Pulling the cable will release the latch.
The inside of the door latch is reached either from filter housing or from top of the machine. Either the filter (usually held by screws) or the top panel must be removed to access the inside of the lock mechanism.
Power must be kept off while doing maintenance. Due to the safety issues involved the door latch emergency opening and repair must be done by a trained technician.
Regards.
Ginko
Dec 15, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
The doo rof my HE Whirlpool duet washer is locked and light says add garment now". I have tried the manual's instructions, and I have unplugged the washer. I have clothes stuck inside the machine,...
Unplug washer and remove lower front panel by removing 3 screws on bottom of panel. You will need "torx" or nutdriver. Reach in and up on right side of inside of washer, right were the door latch is, at the bottom of the mechanism is a manual release. Pull downward on the release and the door should open.
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do we fit a new hinge to a Hotpoint WM64P washing machine
Remove the wire clamp that secures the door seal to the front of the washer.
Pull the seal of the front. and double it back inside the washer.
Undo the 2 screws that secure the door hinge to the front of the cabinet, keeping hold of the hinge support plate behind the cabinet front.
Remove the door, and undo all the scews that hold the 2 halves of the door together, then prise apart the the 2 halves..
Replace the door hinge.
Reassemble in reverse order.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Washing Machines
The door on my front end Whirpool Duet Washer will not open?
Plug off the mains. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
For some front loader models after removing the panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment.
For the door to unlock, press & hold 'end of cycle' for 3 seconds, power shd be on for this, try door after 2 minutes. Your machine may not open if there is water inside, so first drain.
Apr 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to remove the inside left side front door
Snap out two door pull strap retaining screw covers. Remove screws.
Remove screws on front, rear and center of front door trim panel.
Using the Trim Pad Removing Tool or equivalent, pry the trim panel retaining clips from the door inner panel.
These are plastic so be careful you can use a pair of needle nose pliers if you don't have a trim tool.Just start at bottom of door panel and work your way around and up.
Mar 06, 2009 | 1997 Lincoln Town Car
Cannot open door as handle broken for indesitw103
hiya easiest way to open is = first unplug power! then turn off water hoses to machine then draw machine out to gain access to pipe connections on rear and disconnect them ? now remove rear panel top screws as these also secure the top panel at rear then lift rear of top panel and pull to rear the panel now can be removed ? you now have access to the latch on front panel inside? if you reach down you can flick latch /hook clear to open door ? at this point after removing washing? you can observe the door inner remove inner panel that surrounds/secures glass? then you can observe how the door handle/lock assy is secured ? easy diy you can browse yellow pages for the replacement handle assy? machine repairs/spares reassembly is reverse to above wish you well this is a common occurance and should not have prob obtaining parts for the MAKE/MODEL NUMBER ? when enquiring for parts best wishes
Oct 21, 2008 | Washing Machines
Front loader washing machine will not go through spin cycle. door locked shut. cant get clothes out
most frount loaders have and unlock pull ring on the door latch switch, it will mean removing the bottom access panel to reach up inside the machine and pull the release ring down to unlock the door
Apr 21, 2008 | Washing Machines
Getting to the control panel
The outer user interface / touchpad stays in place. it can be removed only after removing the electronic machine relay board. The relay board is accessed from the inside of the door. You need to separate the inner door panel from the outer door panel. After removing the screws from around the inside of the door, the inner panel should lift up and away from the outer panel. The plastic cover should just clip on. you may need to use a flat screwdriver to release one or more of the clips. After that you'll be able to see any screws or clips holding the relay board in place.
Mar 12, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Front door seal or bellow
If, I don't know of any online manuals, maybe one of the other cats do. Check out the link below. Your washer is the same as the HE3, same instructions. Only difference is that on the right side of the panel inside there might be a plastic clip when removing the control panel. Click on the link. Catriver http://www.fixya.com/support/t194538-replacing_rubber_seal_kenmore_elite_he3
Oct 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
29 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
