Question about Brother LS-2125 Mechanical Sewing Machine
Thread breaking. why does my thread keep breaking???????????????????Where am I suppose to change the bobbin tension???I only see the upper tension dial
  • 5 more comments
  • mia12345 Feb 21, 2008
    LOL!!! thank you!!!How could I have spent so much time trying to figure something so simple out...works great now.
  • dawnnshad Mar 09, 2008
    my top thread keeps breaking and its a brand new neddle but very old thread like maybe 10 years or so. i am extremly new to sewing and i mean extremly new. does thread go bad what am i doing wrong?
  • Anonymous Mar 18, 2008
    my top thread keeps on breaking with only a few stitches.
  • Anonymous Mar 30, 2008
    my needle keeps breaking the thread.
    never had this problem in all my sewing years ,
  • angela May 11, 2013
    my sewing machine does the same is there a specific needle for brother x-5 !
  • Anonymous Mar 26, 2014
    thread breaks and is a mess on bottom of embroidery work
  • Anonymous Mar 28, 2014
    Is my thread tension dial on correctly on my Riccar r1500?
    Problem Solver:
  • 15 Answers
Have you tried to change needle?
Posted on Feb 20, 2008
Instructions for threading
search on Google make, model,manual or threading instructions
Dec 07, 2015 | Sewing Machines
The needle thread keeps breaking, I'm using good quality thread and have tried re threading and changing the needle but it still keeps breaking, any advice would be most welcome.
1. Set the tension on the bobbin.
2. When you thread the upper thread do it with the pressure foot up.
While you are threading give slight tugs to check for snags. If there are snugs you must fix them.
3. Put the pressure foot down and adjust the tension to four. Give a tug. It should have tension but still allow the thread to flow.
(Look at your thread and look for fuzz on the sides. This indicates a bad quality thread. A good choice is embroidery.)
4. Make sure the needle has been installed going the right direction. Usually flat to the front or to the right side.
5. Turn the hand wheel while you hold the needle thread to the front.
The bobbin thread should come above the throat plate in about one turn.
NOW YOU SHOULD BE ABLE TO SEW.
LOOK AT INFORMATION ABOUT BOBBIN TENSION.
Jul 23, 2015 | Sewing Machines
My thread keeps breaking after I sew just a little bit. I have changed thread, check it is put on correc. Please advise. Not sure if I have the top tension correct.
1. While threading put the foot up.
2. Give gentle tugs along the way. It should be without feeling any hangups.
3. Wherever the hangup is you must correct. Usually at the tension disc.
4 Sometimes the tension disc is tightening more than the indicator says. It should be about four. You can lower this tension setting until the stitch looks good.
5. You may have to take the tension assembly off and clean it thoroughly and sand any rusted spots.
May 30, 2015 | Sewing Machines
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
Good day!
Jun 07, 2011 | Brother CS-6000
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
Jun 06, 2011 | Sewing Machines
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
Good day!
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
Good day!
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Jun 05, 2011 | Singer Inspiration 4206
Brother LS-2125 Mechanical Sewing Machine Logo
168 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
