Question about Northstar 6000I GPS Receiver
Moisture under screen - Northstar 6000I GPS Receiver
'standard' problem, condensation build up due to poor design planning... open the chart door for a few minutes and it will help balance the temp indifference between the inside and the outside (there is a little vent in there).
Posted on Feb 06, 2010
I have an Electrolux Oven EVEP6155A. I have a fault Code F239 showing on the screen Can you please help
this is a error for the touch controls its normally caused by moisture getting on it, theres an upgraded part you can order from electrolux which is basically just a strip of foam you fit under the touch controls to prevent moisture getting in
Dec 24, 2016 | Electrolux Ovens
Remove moisture inside Olympus digital camera
Place it in a sealed container covered in rice for a few days. The rice will absorb the moisture. Works on cell phone dropped on water too.
Sep 02, 2014 | Olympus TOUGH TG-310 Digital Camera
We got moisture under the screen, how do we get it out?
I have a couple good screens I can sell you one for 10.00 without moisture.
Sep 01, 2012 | RCA DRC629N Portable DVD Player
Moisture from hot tub got under the touch screen of my cell phone, and now it's not responsive to touch. Is there anything I can do?
When most cell phones get wet or aquire moisture the circuit boards on the inside rust as they dry out so if the phone is insured I woudl just suggest replacing it because the rust on the inside will continue to affect the phone even after it is dried out. Depending on who your carrier is you maybe able to have a tech open up the phone and clean the circuit board with some solution. This is not something you should attempt your self because it would void any warrenity remaining on your phone. If you have a warrenity and you phone is not visibly wet and all your indicator on your phone are still negative for water damage (stickers located on or around your battery to show that your phone has water or moisture damage) then just take it in for a replacement but, leave out the part about moisture just tell them the touch screen is not responding
Nov 30, 2009 | Samsung Behold Cell Phone
How to take apart the LG Versa to dry out moisture behind the touch screen. It went through the washing machine, appears to work otherwise though
I would not try and remove any backing or covers off cell phones. I dropped my cell in the lake a couple of years ago. I took the battery out and laid the phoone and battery on my dash for a couple of days and this baked out all the moisture. the phone still works today!!
Oct 26, 2009 | LG Cell Phones
Leapster screen won't work
Since the FixYa team makes about as much sense as stereo instructions,Froggy,I might be able to help.The moisture on your screen is either very very bad or semi bad.It is either condensation or it is battery fluids,and in the case it is battery fluid,put in a air tight bag,Battery fluid can be radioactive more or less.Otherwise all condensation will do is make your screen smearable.For the not working part,the wires might be frayed.Otherwise its a bad packet.But DO NOT TAKE THE SCREEN OFF UNDER ANY CIRCUMSTANCES.A:It could destroy the systeme,and B:if it IS battery juices it could be very very bad for your health.Hope I helped.
Apr 01, 2009 | Nintendo Game Boy Advance Console
Malfunctioning GPS
You may have dust particles or similar trapped under the touch membrain. This would cause random selection and result in the problem your'e describing. It's often the case that small particles can be trapped just under the edges of the screen by getting under the screen surround( bezel ).
Another similar problem can also occur if the TomTom is left in a cold car overnight after a warm / hot day where moisture can form under the touch screen membrain. This moisture can move around making random inputs to the screen.
Hope this helps.
Good Luck
Sep 09, 2008 | Tomtom ONE GPS Receiver
Moisture under top screen
Well if it got in it will eventually come out. However it could takes weeks or even a few months for the condensation to completely go away.
If i were you i would open it up and dry it out but if you don't have the knowledge to do it or are just nervous to void your manufacturer's warranty then i'd just wait it out til it goes away.
One thing that may work. If you have a dehumidifier put it on top of it and turn it on. Dehumidifiers suck the moisture out of the air. It may work however i doubt it.
Jan 26, 2008 | Nintendo DS Console
Modelnn-h264/s254 1100 watts
This door screen as it's called protects the metal mesh screen from moisture and food debris. The door screen must be replaced or the mesh screen can arc and be damaged, which can lead to microwave leakage. You can order a new screen from Panasonic at: http://www.pasc.panasonic.com/Epartr/PartsListChoice.asp It may be this part: F31455H00AP DOOR SCREEN A 5.75 But it might be better to call Panasonic at 800-833-9626 and be sure this is the right part. Be sure to have your FULL model nuber (with suffix) when you call. Be sure to use a cleaner like acetone, etc. to remove all the old adhesive before applying the ne wone, or it will not stick. The door must be squeaky clean and dry.
Sep 21, 2007 | Panasonic NN-H264 Microwave Oven
Northstar 6000I GPS Receiver Logo
293 people viewed this question
Top Northstar GPS Experts
Are you a Northstar GPS Expert? Answer questions, earn points and help others
