Question about Samsung SCH-i730 Pocket PC
SCH-i730 doesn't charge . I cant even turn it on with a usb cable attached. I got a new battery and it worked well untill the charge died. Cable is good and it did sync my phone to the PC but still even when the phone was on it didn't charge it.
SOURCE: blackjack2 not charging!!!i'm fucked
Same exact problem for me...word for word. Sometimes I can get the charging to start by removing and replacing the battery. But my BJ2 rarely charges properly when I first plug it in.
Posted on Jun 11, 2008
SOURCE: syncing won't work
I am reading the first solution to getting the issue fixed with the phone not being recognized and i am still at a stand still. I dont know how to find the settings that it referrs to or the mass storage..I just got this phone and I can not get it to sync at all. just keep getting error messages...PLEASE HELP!!!
Posted on Oct 14, 2008
  • 16 Answers
SOURCE: samsung sch-i730 touchscreen is out
go to start,settings,tap screen then align
Posted on Jan 21, 2009
  • 17 Answers
SOURCE: samsung sch-i730 cant access wi-fi
To acces the internet have you tried:
START
PROGRAMS
INTERNET EXPLORER
For Wi-Fi:
START
SETTINGS
Wi-Fi
Tap red bar to switch from Wi-Fi Disable to Wi-Fi Enabled.
Posted on May 29, 2009
  • 16 Answers
SOURCE: just wondering how to connect it to a computer?
ya i think the problem is the battery is just going and u can get usb cable or an intire usb cradle 4 it just search "samsung i730 usb cable" on ebay 4 tons of cheap cables 4 about 6$ with free shipping
Posted on Jul 06, 2009
My samsung sch-u450. will not charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 30, 2012 | Samsung SCH-U450 Cell Phone
Nokia 5800 not holding charge
First Option:
Second Option:
Sep 13, 2012 | Nokia 5800 XpressMusic Smartphone
USB PORT NOT WORKING HOW MANY WAYS CAN I CHARGE MY SAMSUNG SCH R450
check your connectivity cable might not compatible or replace it.
Sep 09, 2012 | Samsung Usb Data Cable For Sch-r450...
Livescribe smartpen (Echo) not able to charge
Hello.
Sounds like the micro USB cable is defective and needs to be replaced. But, first try the cable on another USB port to be certain that the USB port is OK.
Hoope this helps.
Jan 05, 2012 | Smart Pulse Livescribe pen
My camera cant charge if I put it on the light it dosen't CHARGE EVEN IF I PUT MY USB CORD WHAT SHOLD I DO?
Please note that the camera will only charge from the computer if the camera is turned off. Also try a different USB plug. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare M863 Digital Camera
Just wondering how to connect it to a computer?
The Samsung SCH-i730 doesn't have a USB port, but it has a different port that underneath the phone itself. You need to use an adapter so that you could connect it to the computer. Look for the adapter SCH-i730 Lil Sync USB connector.
There could be a possibility that the battery is not working correctly. To isolate this, try to use another battery to see if you will get the same problem.
NOTE: To take care of the battery, never charge it if it's not running out of charge. Never unplug the charging battery if it's not fully charged.
Apr 15, 2009 | Samsung SCH-i730 Pocket PC
Insignia 5.0 mp hd camcorder. How do I charge the battery?
Make sue the text side of the battery is facing up. Not the pure black side... I was having this problem until I decided to flip the battery around and it worked just fine...
Jan 09, 2009 | Cameras
My samsung SCH-i730 is stuck on the white loading screen
You may have to do a major reset on it. First remove and replace the battery and turn it on again. If that doesn't fix it, there is a tiny reset button on the bottom near the connector. You will need to push it in with a small point such as a paper clip wire.
Jan 03, 2009 | Samsung SCH-i730 Pocket PC
Battery won t charge or operate phone Problem - T-Mobile MDA Compact Smartphone
Okay, I searched and searched until I found a solution that worked for me. I tried the USB thing, I got my phone to turn on once, but never to charge. Here's what I did:
(Do this at your own risk)
I zapped my battery with a 9v battery. One wire on each terminal and then held it to the MDA battery (positive to positive, negative to negative) for about three seconds. I did this about five times. (Don't let the wires touch while they are connected to the 9v battery.) I IMMEDIATELY plugged my phone into a wall charger, NOT my computer (The computer wouldn't charge my phone). As soon as it was connected to the wall charger, I turned it on. After starting up, the orange light came on, and it started charging. I was skeptical about this solution at first, but trying everything else I resolved to do this and then if it didn't work buy a new battery, but it worked and my MDA is charging as I'm typing. The original ideal came from a post on the xda-developers website by dew1989. I added the additional steps that got my battery charging again. I hope this helps!
Dec 04, 2007 | T-Mobile MDA Compact Smartphone
Samsung SCH-i730 Pocket PC Logo
95 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
