Question about LG HT503TH Theater System
My LG503th system doesn't play dvd's anymore...it says no disc and won't read the dvd - any ideas??
  • 4 Answers
Its the spindle motor
Posted on Feb 11, 2010
  • Music-mad23 May 22, 2011
    Does it read cds
Is my Blu-ray laser broke?
Yes you can replace the laser yourself should be easy go and look on eBay or Amazon I would take out your old one first and get the model number from it.
Aug 13, 2014 | Televison & Video
Chrysler grand voyager dvd in car system won't
Does it play a cd? If so than the decoder for the dvd portion of the head unit may be bad. I would replace it if that's the case.
Jun 17, 2013 | Cars & Trucks
My dvd gaves me a bad disc
when you play nothing but bootlegs in a dvd player, they tend to burn out the eye inside the player to where it will only read bootlegs. the original movies capabilities won't work anymore. hope this is a help to you my friend.
Jun 21, 2012 | Cyberhome CH-DVD 300 DVD Player
Compact Disc rewritable DVD player won't load or play
Check the data connector on the rear of the drive. If this doesn't work you may need a new drive, they are cheap and readily available.
Jan 19, 2012 | Lenovo Computers & Internet
Won't read d d keeps saying bad disk
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Oct 05, 2011 | Curtis DVD1041 Player
My CD/DVD drive won't read/play DVDs and it won't write DVDs either. It used to do this fine, but it doesn't anymore. It will still play and write CDs, but not DVDs. I have tried EVERYTHING to...
You probably will need to replace the optical drive (CD/DVD drive) in your laptop. Go to Google and search for "Dell Inspirion 6000 CD/DVD drive" to find a replacement.
To be sure it's the CD/DVD drive that's defective and not your operating system software, you could also try to boot from a boot-able DVD disk.
Jun 23, 2011 | Dell Inspiron 6000 Notebook
Dvd player won't play disc
The DVD read head may need to be cleaned. Sometimes perfectly OK drives also fail to read certain discs. If the problem is persistent, i.e. the notebook won't read any discs, then clean the head (with a head cleaner) and try again. If it starts working, fine.. If not, then you may have to replace the DVD drive. If the problem is only related to playing one particular DVD, then its the DVD that is faulty.
Hope this helps.
May 25, 2011 | Toshiba Satellite P505D-S8935 Notebook
My LG503TH doesnt like to play DVDs anymore, if the disc has any scratches at all it pictulates, even new discs need to be cleaned (glass cleaner and paper) to get some to work. the system is only just 24...
hi,
your system has problem with its laser pickup unit. u have to replace the same.
when the laser pickup loose its intensity this problem will occur.
try on thing before replacing the same try to clean it lens. do not use any solutions for cleaning the lens because it is made of with fiber. us a good type of cloth or an ear bud. do not apply pressure on the lens clean gently. then try to play a disk if the problem remains off course u have to replace the laser pickup unit.
ok
Jan 06, 2011 | LG HT503TH Theater System
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
LG HT503TH Theater System Logo
357 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
