Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Samsung HL-P5063W/ Please Help
Please help
When a try to turn my tv on the lamp and timer light flash green for about 4 seconds I get sound for about 10 seconds then the tv goes off.
  • 29 Answers
Could be a main board or a DMD board .
Posted on Mar 15, 2008
HL-P5063W Turns on, but no picture.
remove and inspect the lamp the model indicated uses---you can usually also look from the rear to see if lamp comes on at all---set also prone to bad color wheel--grinding or high pitched fan like sound--it faces the lamp--with lamp removed look to see it is not shattered or missing pieces and that lamp not shattered inside.
10_22_2012_4_53_15_pm.jpgtypical color wheel
Oct 22, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
Have a 50 inch hlp506w model samsung projector tv. it had wavy lines through it, and then turned off. it is continuing to try and turn on with the standby/temp and lamp lights flashing. replaced lamp...
Change the tv Ballast board too.This board only job are to help it to ignite the tv projection lamp. This tv also have a colors wheel design into it too.If tv have colors pictures flashes or Black& White flashes within it pictures or tv have grinding noises or humming sounds,than the tv colors wheel it is warp and dead.This tv colors wheel must be replaced,because the colors dis wheel is warn out.
Jul 05, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
Sep 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Replaced color wheel and the lamp...tv still. Cycles on and off..with "lamp" green light flashing along with standby light flashing...nothing on screen and lamp not coming on? Its an hlp5063w. Please...
Since you have replaced the lamp and wheel, next would be the ballast and power supply board. These provide power to the lamp and Samsung recommends replacing both at the same time. If power supply board is bad, it can destroy the ballast so replace both. This usually takes care of the problem.
Aug 06, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
HI FOLKS, I HAVE A SAMSUNG HL-P5063W DLP TV THAT WON'T TURN ON. WHEN I PLUG IT INTO TO WALL I GET THE SOLID RED STANDBY/TEMP MESSAGE ON FRONT ON/OFF BUTTON. THEN WHEN I TURN IT ON, THE STANDBY/TEMP MESSAGE...
Bad Lamp Call FOX 1-800-227-5369 Lamp number is
BP96-00608A or BP96-00826A $109.00 Mats Electronics is another company for Lamps 1-800-628-1118 or Find one on E-Bay
Nov 30, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I just replaced the lamp on my samsung HL-P5063W (DLP TV)...now the TV will not turn on (no picture...but I do get sound)...when I plug it in, it automatically starts to power on...then it starts making...
Sounds like a bad color wheel. Generally when the color wheel goes bad, when you try and turn the TV on the lamp will ignite for a couple seconds and then turn off. It also makes a rather high pitch squealing noise.
www.Partstore.com should carry a replacement color wheel for your TV
Sep 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Red light flashing 4 times, tv turns its self off
Start by removing and inspecting the bulb. The filament you're looking for is encased in the glass tube in the center of the lamp itself. Kindof difficult to see unless you're at the right angle. 9 times out of 10 that solves the problem. If not move on to the ballast, the small circuit board directly underneath the lamp housing.
Jan 29, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP HL-P5063W
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
93 people viewed this question
Henry  Thomas
Henry Thomas
