My HP 1510 All-In-One insists in displaying 1 copy waiting each time I switch on and of course the red light comes on because there is no paper in the machine. If I leave paper in the machine all I get is another copy of a test page. How can I reset the default to delete the 1 copy waiting each time I switch on? I cannot acces the configuration settings by default I presume.
  • Deny Mulia
    Deny Mulia May 11, 2010
    did you try to press cancel from printer machine?
I have problem check printer 5B00 MX318. Want to know how to edit it?
Posted on Feb 05, 2010
Prints test copy every time I switch it on.
All right so you are getting print test copy every time you turn on or switch on your printer. You can follow the following steps to fix this issue:-
1.. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place the test page on the scanner glass and press the SCAN button on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages! Yay!
(You may now reconnect the printer to your computer via the USB cable.)
let me know if it fix this issue and helpful to you.
Mar 03, 2011 | HP PSC 1510 All-In-One InkJet Printer
Printer sporadically displays a red light three successive flashes error and will not respond to till / keyboard. What does this mean?
PUT PAPER INSIDE PRINTER POWER OFF THE PRINTER.
THEN PRESS & HOLD THE BUTTON ON TOP OF PRINTER
BY HOLDING THE BUTTON NOW SWITCH THE PRINTER ON & WAIT UNTIL THE SIZE OF PAPER IS SCANNED .
IT WIILL BE DONE.
Feb 08, 2011 | Epson TM88II Thermal Printer
I have an HP C4200 Printer-scanner-copier and when it tries to pull the paper in to print it says ''paper jam''. There is no paper in there that I can see.
1. Please visit the below web link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3300218&lc=en&cc=us&dlc=en&lang=en&cc=us
2. select operating system
3. Downloa printing diagnostic utility
4. Run it and diagonize
5. Fix it and restart
If the issue still persists, then
Perform a reset of the HP All-in-One
  1. Press the On button and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the HP All-in-One.
  4. Wait for 20 seconds.
  5. Plug the power cord back into the HP All-in-One.
  6. Plug the power cord into the wall outlet.
  7. if the issue still persists, then perform the below steps it should resolve your issue.
  8. 1.Power Button + Cancel Button Combo
    2.Enter special key combo 1[Scan] 3[Copy Color] 2[Copy Black]
    3.‘Support menu’ will be displayed
    4.Press the 2[Copy Black] until the display shows ‘Reset Menu’
    5.Press the 3[Copy Color] once
    6.Press the 2[Copy Black] until the display shows ‘Semi full reset’
    7. Press the 3[Copy Color] once
    8.The printer will go off and will power on by itself, else wait for 20 seconds and power on the Printer
  9. Turn on the HP All-in-One by pressing the On button.
Sep 03, 2009 | HP Photosmart C4250 Multifunction Photo...
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
HP Business Inkjet 1200 Lights flashing
Check the paper sensor has not come loose. Lift the lid, it is on the right hand side of the rollers with the red and blue wire. Press down lightly to make sure is hasn't come loose.
If not, reset the printer:
While the printer is on, press and hold the configuratuion button and press resume (paper feed) button 3 times.
Wait 20 second and press the power button.
Disconnect the power and wait 20 seconds.
Connect the power and switch the printer on.
Feb 24, 2009 | HP Inkjet 1200dn Printer
Won't print - just flashes it's lights at me!
I tried what phrek said (" Pressing the flashing buttons simultaneously, evokes the printer to spit out an internal diagnostic page ..."), but after the diagnostic page printed out the printer worked fine again.
Thanks for the help, and hopefully things work out for the rest of you as well.
Aug 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
PAPER JAM THAT REALLY DOESN'T EXIST
make sure the back cover (black panel) is fully closed. If it is, remove the panel and shake gently to make sure nothing has fallen inside.
Mar 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Paper tray
place the sheet properly in paper tray like put deep inside like when you feel some resist stop it putting inside
Sep 08, 2007 | HP PSC 1510 All-In-One InkJet Printer
155 people viewed this question
jasbo
jasbo
