Question about Minolta X-700 35mm SLR Camera
My camera doesn't work when I press the shutter release
I have been having some issues with my X-700. First, the shutter curtain has only been opening part way and then today, I shot off a couple frames and now it isn't working at all. When I press the shutter release, nothing happens and the film advance lever is not doing anything either. I tried putting fresh batteries in but nothing happened. Any suggestions?
  • Christina_93 Feb 27, 2008
    I can use small tools. What do you think the problem is?
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    Hi, Are you handy with small tools? This one will require taking to bottom cover off the camera (4 screws)
Could you please tell how to re-time the gears? X)
-david
Posted on Nov 01, 2008
I'm not Christina, but my X-700 has somewhat the same problem. I have already fixed the "no shutter fire situation" by replacing the caps but now I notice something different. Looking from the back of the camera (door open) I see that the shutter curtains are not aligned properly during a wind. The one one on the right is slightly cocked, its metal strip is not hidden behind the other curtains edge. Is this something that I can handle? I have all the tools.
Thanx,
robert!
Posted on Oct 16, 2008
  • 667 Answers
I think the timing of the shutter winding gears has slipped a tooth or two. look at the picture in this image:
http://www.twid.de/x700/pic03.jpg
Near the motor drive coupler at the bottom you will see a blue and a white gear. Look closely at the blue gear and you will see a line on the top of it. That line needs to be pointed at the center of the white gear when the camera has been released and ready to be advanced again.
If you wish to proceed, I will tell you how to re-time the gears.
Posted on Feb 28, 2008
Shutter Curtain Doesnt Reset Mirror
If your shutter curtain doesnt close, it may be out of Sync with the shutter button. My Minolta x700 had this problem. My camera guy fixed it for me with a couple of tinker moves. Contact your nearest camera repair shop (if available) and ask how much it would be to fix the Sync between depressing the shutter button and the curtain. it may just be some grime that has it stuck.
Mar 18, 2014 | Minolta X-700 35mm SLR Camera
Olympus om2 stuck shutter
I have seen this before, especially on OM2-SPs, the wind on mechanism cam seems to get out of register with the shutter curtain rollers. If you remove the baseplate from the camera (4 screws) and release the cam that drives the first shutter curtain roller, this can release the shutter. You then have to re synchronise the cam with the winding mechanism, tricky, but it does work and can be done with some patience! Good luck!
Mar 26, 2013 | Olympus OM2 SPOT/PROGRAM OM2SP SPARES OR...
Shutter does not operate.
hiwhen you say shutter does not operate, it mean too general to answer. could you provide more detail?I will give how does shutter work. First, you press shutter button, it will activate two switchs (one is focus and meter and the other is release ) Second, mirror goes up and opening shutter curtain move up. Third, closing shutter curtain down and mirror down and picture come out. Of course there is also aperture control unit sequence.
Jun 04, 2011 | Nikon D40x Digital Camera
I have a hasselblad 503cx. when i hit the shutter button, the back part of the lens opens (where the film is) but the lens shutter is closed. when i let go, the lens opens and the back closes.
The proper order of exposure should be:
Curtain opens/Lense stops down (unless wide open)
Lense shutter closes
When releasing button, curtain closes
When winding, lense shutter opens
If this isn't what's happening, something is wrong. There is only a simple mechanical screw connection between body and lense, so it'd have to be an issue with the gears in the body.
May 21, 2011 | Hasselblad 503CX Medium Format Camera
I was loading film into my Nikon EM for the first time and it wouldn't work so I had to take it out, then I pressed the shutter and it closed and it didn't open back up so I played around with the shutter...
You can't touch the shutter curtain at all on any film camera and the cost of repairing that curtains far exceeds the cost/value of the camera. Sorry for the bad news but the only thing worth anything on the camera now is the lens.
Dec 10, 2010 | Nikon EM 35mm SLR Camera
Rebel 2000 went retarded
I got a Rebel 2000 off ebay, and it had the same problem. The Shutter wouldn't open, it showed dead batteries, and the mirror hung until I pressed the shutter button or changed modes.
After a good deal of surfing, I found that the most likely reason was a sticky/oily shutter
(http://photonotes.org/articles/oily-shutter/).
Since I didn't have much $$$ invested in the camera, I tried cleaning the shutter curtain with Qtips and alcohol. After a little cleaning, the shutter started to move. After a lot of cleaning, the shutter moves freely. I ran a roll of film through it, and it seems to be working just fine now.
Feb 27, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Shutter release
Hi , to release the shutter open the lense and push shutter button , rotate the camera mode to auto or manual release shutter.donnot set on bulb or lower speed can cause stuck camera miror and stter curtain, or blade.
Feb 19, 2008 | Photography
Picture nearly all black
Lets see if the shutter curtains are opening properly : set to B and open the film back of the camera. Now release shutter and see if the first s. curtain has opened nicely and swiftly. Then release the second s. curtain and again see if you get proper closing of the curtain. If the shutter curtains ( usually just one misbehaves ) is slow to close then the shutter unit needs looking at . ( btw no point pouring liquids like benzine etc. into the shutter curtain are ... will make things worse ).
Sep 26, 2007 | Canon EOS Rebel G 35mm SLR Camera
AE-1 Didn't Take Pics
Possibly the film did not go through the camera. If it did, the problem may be the 2nd(or closing)curtain magnet on the bottom of the camera. When the magnet is working the closing curtain of the shutter is held back 1 to 1000 miliseconds-depending on the shutter speed selected by you. 1ms=1/1000 sec. 1000ms=1 sec. You can tell by 1. removing the lens 2.setting the shutter speed to the "B" setting 3. opening the film door and looking through the camera 4. releasing or firing the camera and keeping pressure on the release button. If the magnet is working, the shutter will stay open as long as the release button is kept pressed down. The closing curtain will close as soon as the release button is released. When the magnet fails, both curtains travel across the film plane together and no exposure is made. Sometimes there is corrosion on the magnet where the wires connect. Sometimes there is some foreign substance or object that interferes with the face of the metal unit that attaches to the magnet when the camera is wound. Sometimes the magnet just fails and needs to be replaced. If the magnet checks out OK the problem may be in the circuits that control the release of the magnet. If this is the problem, the camera needs to be looked at by a competent repair shop. Just so you know, new parts are getting hard to come by, but there are tons of used cameras around that parts can taken from. Hope this helps.
Jun 24, 2007 | Canon EOS-AE-1 35mm SLR Camera
Minolta X-700 35mm SLR Camera Logo
391 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
