Question about Freezers
Sub-Zero Under Counter Ice Maker not making Ice
I have a 9 year old Sub-Zero under counter ice maker that is having problems making ice. I have cleaned the system thoroughly, including the freezing tray. When I turn on the ice maker the pump starts to pump water up to the freezing tray and the water runs down over it. After a short time a sheet of ice forms on the freezing tray but it never releases and slides down to the cutting tray. I have let it run for several hours and the ice never releases and gets cut. Any suggestions would be welcome since I feel like I have tried everything except replacing the freezing tray.
Thanks in advance.
  • 2 more comments
  • tritontx Feb 21, 2008
    Thanks for the quick response. The model number on the tag on the inside is of the unit is 23560. The number on the Use and Car Guide is 2185887. I haven't been able to find anything on the net with this model number so I hope you can help. The timer thought would make sense. Is the time neare the pump assembly or is it under the freezing tray?
    Thanks again.
  • tritontx Feb 26, 2008
    I have an update. The Model # is 235/S.
    I don't understand the last posting so could you please clarify?
  • nascar 1 Jun 12, 2008
    water is not freezing on the freezing on the water plate,had it running for over 4 hours just maybe 1 inch ice was forming in the corner,water justed kepted running down over plate,maybe needs free-on not sure please help same model 235 thanks
  • Gary Davd
    Gary Davd May 11, 2010
    Plz post your model several mfg. have made units for them so i can see what model you have ..But just off the top of my head you have atimer that is not letting the unit go into defrost
    Problem Solver:
  • 6 Answers
Ice stat defective
hot gas solenoid vavle defective
pls post make /model.
if ignis / whirlpool then above points should the trick.
lastly reclaim gas replace both driers recharge with fresh gas to spec( liquid by weight).
Posted on Feb 26, 2008
Ice will make and almost overflow and then freezes up at cutter. Who can I call to repair?
Hello Lisa;
My name is Peter. I am a retired field service refrigeration technician.
It sounds like you have a broken wire in your cutter. This is a easy part to replace. You have an electrical connector and some screws to remove.
If I were still working for , "Sears Home Services", with part I would be charging you about $300.00 -$350.00 for a repair that you can do yourself.
Go into the following website. Plug in your model number. Get the part number, then search the internet for bet price. You can repair this.
Water Filters Lawn Garden Appliance Parts
Mar 24, 2015 | Electrolux "15"" Under-Counter Ice Maker"
Electrolux ice maker won't stop making ice
The bin full detector is not working--replace it.
May 21, 2014 | Electrolux 15 Under-Counter Ice Maker...
Our ice machine is making too much ice. When we open the door, ice spills out - so for some reason, whatever triggers the machine to know that it has enough ice made, seems to be malfunctioning. Any...
When frost builds up on the little flapper at the top of the door above the ice maker it can get stuck. It tells the ice maker to keep making ice. Try cleaning the mechanism of frost and make sure it operates freely.
Oct 17, 2013 | Electrolux Stainless Steel Under-counter...
Sub Zero ice maker (Model 235) not making ice, warm inside
try first. condenser ciol clean. is the water cold? is cutter grid in god shape? the brackett under the evaporator is attached?
Apr 02, 2010 | Freezers
Ice maker is not making ice
Subzero ice makers arent all cut and dry. You could have an intermittent issue with either the ice maker itself, or the solenoid valve. SZs also often utilize a door switch which prevents the ice maker from operating if the door or the basket which the ice bucket sits in are not closed or in the proper position. If you have had other what would seem minor problems, that you have lived with, they can inadvertently affect different things. Most sub zero ice makers you can start manually by rotating the ejector comb clockwise as you look at the front of the icemaker, when the icemaker completes its cycle, do you get water to the ice maker, and do you get enough water, usually 140-150 ccs. If the ice maker continues rotating on its own after your initial start up, and receives the proper amount of water, either you have a cooling problem, a door or something is not in the correct closed position, you have a bad switch, or the ice maker is bad. If you receive little or no water at end of cycle, you have a bad valve.
Mar 25, 2010 | Sub-Zero 15.3 cu. ft. / 433 liter Upright...
Sub Zero 5065 Under Counter Ice Maker
We have a sub zero 5065 in our storage, still unused and in the box. You may want to just buy it at a good deal. Make an offer, it has to go as we are cleaning out the storage are. 360-695-3238 Brian
Mar 18, 2010 | Freezers
Freezers Logo
784 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
