Question about Epson RX620 All-In-One InkJet Photo Printer
I have a HP3600n printer and in my document have grey shaded areas which are printing green. Any suggestions
  • 677 Answers
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 06, 2010
Yellow is printing dark muddy colour, tank content same colour.
Has the printer printed a good yellow using this ink tank at all?
Dec 12, 2013 | Brother Office Equipment & Supplies
My Xerox 8400 is printing the wrong colors. Where it's red, it's printing a brown shade and where it should be grey, it's printing green. My logo is grey and red and it's printing all grey, but not the...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
This problem is common in situations where a lot of black and white printing is done, with very little colour.
Alternatively, it could be that your wiper/cleaning blade is not cleaning the head properly and is smearing the different coloured inks across the head, or possibly that your printhead is leaking colours but I think the first solution should solve your problem.
Hope this helps.
Dec 09, 2010 | Xerox Phaser 8400 Laser Printer
Samsung 5935 copies black after changeing main board
Double check your cables/ harness especially to the document scanner section.
If you can print internal test pages ok, without the background, then a part of the document scanner is bad. The document scanner CCD JC96-05207A which is what reads the document.
Also, there is a "shading profile" adjustment, in case you just have a little grey background.
Whit
Item, Inc
Oct 27, 2010 | Samsung Office Equipment & Supplies
Won't print words!
sounds like a couple of things....
the document program your using, when printing, check to see what is printing (pages) you can select one, current page or multiple. also check the attributes for printing.
check the settings for the printer, you might be out of ink
lastly, in the document, go to the Page File and scroll down to see if the shaded areas need to be 'set to back'
hope this helps and good luck
Apr 29, 2010 | Brother MFC 490cw Color Inkjet...
Dell 3110cn Printer prints shades of pink
Have you pulled out the imaging drum and transfer roller to see if they are caked in Magenta toner? if so they will need to be cleaned off. Would also suggest blowing out the area around the drum to rid of loose toner in that area.
Feb 15, 2010 | Dell 3110cn Laser Printer
We can not print the green color in my graphics
Get new cartridges. Refills only work a few times then the jets then to dry up.
Apr 28, 2009 | Office Equipment & Supplies
Will only print photos in shades of green and grey.
Not being able to scan properly and improper colors are most often caused by glitches in the software. Try reinstalling your driver with a new updated driver for your machine.
Here is a link to the OEM page:http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?pq-path=9106
This is the all in one driver. Install this and try again and it should fix it. Let me know if it helps.
Mar 29, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Scan views fine; prints fuzzy
Try to change the dpi to the maximum, maybe 600 dpi. This will make the picture more defined.
Nov 19, 2008 | Brother MFC-7820N Printer
Printing pdfs with highlighted text/shaded areas
That just means that you don't have a postscript enabled printer, or possibly you're using a black and white only printer. You might be able to print highlighted items normally on other printers, but will have to remove the highlighting to see the text on the one that you have. Alternatively, if removing the highlights isn't possible, you might try selecting all the text and then pasting that into a new document in a word processor or another similar program. If you do have a color printer, and need to print what you're seeing, you can arrange the document so that it is centered on your screen and then press: "Alt + Print Screen" at the same time. You can then open MS Paint or a similar photo editing program and paste ("Ctrl + V") the screen capture into the program.
Let us know if you need further help.
Hope this will FixYa!!!
Oct 30, 2008 | Adobe Acrobat 7.0 for PC
Half the page is dark grey
Low toner.
Consider how often you print.
If you print more than twice a day, toner will tend to run low after half a year, so I would buy a replacement cartridge and see if this solves your issue.
They aren't terribly expensive, so it is worth a shot.
Sep 09, 2008 | Samsung CLP 300 Laser Printer
Epson RX620 All-In-One InkJet Photo Printer Logo
54 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
