Question about Kenwood KFCM6925ie 6x9 3-way 200-watt Car Speakers Car Speaker
I would like to know what the best way is to cut out bass response in 4x6 and 6x9 speakers in a car w/o having to install a 4ch amp running in HPF mode. any suggestions?. i read about small inline capacitors but i haven't the slightest idea what one i would need or how to connect them. any help would be appreciated :)
  • GRNDMSTR Feb 06, 2010
    Will this setup work w/o an amp? currently they are being fed thru the factory wiring coming off the headunit.
  • 547 Answers
You can indeed do this by putting a ceramic capacitor inline with the speaker wiring.
The circuit you have now goes Amp+ to Speaker+, Speaker- to Amp-
putting a capacitor inline means your circuit will go:
Amp+ to Capacitor, Capacitor to Speaker+, Speaker- to Amp-
Ceramic capacitors don't have a + or - side.
The next question is what value of capacitor do you want, and that answer depends on two things -- how much bass you want to cut off (the cutoff frequency) and the impedance of your car speakers (generally 4 ohm, but some are 8 ohm and some are 2 ohm)
Here's a spiffy chart that shows the relationship between cutoff frequency and capacitance. There's a lot of data there. If you get overwhelmed, here's a suggestion:
Assume you have 4ohm speakers, and you want to cut out everything that's going to a subwoofer (120Hz and below) -- you want a capacitor of about 330 uF (microfarad)
You can get those at any radio shack, or order online from someplace like Mouser.com
Posted on Feb 05, 2010
  • Rob C Feb 06, 2010
    Yes, you bet.
  • lfsanderson
    lfsanderson May 16, 2012
    Yeah... or you could be untechnical and turn on the high pass filter LoL!! my old headunit has it as a setting.. my new one doesn't... but every EXTERNAL amp will have the option... lol
I have a koiiler xm-8787 1000w amp. the problem is when i hook everything up correctly, the dual 10 inch sub make a repeating papapapapapapa none stop and doesn't produce bass. could it be the amp is...
I HAVE THE SAME AMP IN MY CAR RIGHT NOW ! THATS NOT NORMAL THATS FORSURE THERE SHOULD BE A X-OVER SWITCH ON THE SIDE OF IT SWITCH IT T0 LPF (LOW PASS) THERE SHOULD BE A DIEAL LABELED THE SAME THING ADJUST IT TI 75% TURN YOUR BASS BOOST TO 25% AND THE LEVEL SWITCH TO 25% THE HPF DIAL WONT WORK UNLESS YOU SWITCH YOUR X-OVER TO HPF BUT YOU DONT WANT THAT, THAT HAS TO DO WITH THE VOICE3 COILS IN THE SPEAKER THATS PROBABLY YOUR PROBLEM! YOU WANT TO RUN YOUR SPEAKERS WIRES PARRALLEL WITH A DOUL VOICE COIL SPEAKER IT SHOULD HAVE FOUR TERMANALS ON IT RUN YOUR NEGATIVES TOGETHER THEN RUN YOUR POSSITIVES TOGETHER AND SEE IF THAT WORKS! GOOD LUCK!!!!!
Oct 22, 2010 | Koiiler XM-6666W Car Audio Amplifier
I have a 250 watt / 4 ohm subwoofer i have a diesel 700w amp / 2 channel / hpf or lpf with bass boost. i dont have speaker wires and want to utilize my to speakers in the back of my 2008 mustang to...
if you are trying to use it with the stock headunit you would need to buy a line output converter to use your amp and sub. after you buy the converter you will then need to splice into one of your rear speaker wires so you can run the rca's to the amp and continue with normal install
Aug 10, 2010 | Diesel Audio NS-700 Car Audio Amplifier
I've got a 1999 ford expedition with the Mach radio system in it and it does not have any bass playing thru the front or back speakers and i've changed out the factory amp thats in the back where the sub...
does the new amp you have have a hpf setting if so check to see if thats on, turn off the x-over so it will play both lpf and hpf, bass and treble. are all the speakers wired to the amp aswell, this is the only thing that would stop bass other than the head units settings.
Jun 21, 2010 | 1998 Ford Expedition
There is no bass coming out of the speakers why?
check the crossover setting on the amp and try bringing it down to 80hz and make sure the filter is set to HPF
Jun 15, 2010 | Alpine MRP-F300 Car Audio Amplifier
When i turned the bass up to high on my head unit my amp cuts out on overprotection, just for a second and them comes back on. why?
go into your settings in the deck by holding down the volume on most models for 10 seconds then change your hpf settings and your lpf settings your bass will sound much better and not cut out. hpf recommended 160......lpf recommended 140.... good luck
Jun 03, 2010 | Car Audio & Video
No bass
Your amp may bet set to "HPF" which is a high pass filter. It needs to be set to LPF
Apr 13, 2010 | Kicker 02S10L74 Car Subwoofer
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
HPF and LPF problems
it would be best to contact the retailer for the headset and get better assistance for this.
Dec 11, 2008 | Sony Ericsson W200i Cellular Phone
Hooking up a new 8" woofer speaker to my amplifier
If I'm reading the amp manual right, you should be able to connect the amp in 3 channel mode. To do this:
  • Connect both left door speakers in parallel to Ch A Left.
  • Connect both right door speakers in parallel to Ch A Right.
  • Bridge Ch B and connect it to the new 8" sub.
  • Set the Ch A LPF/HPF to HPF.
  • Set the Ch B LPF/HPF to LPF.
This should allow you to run all 4 door speakers and the sub from the amp. It will also automatically route non-bass to the door speakers and "only bass" to the sub.
Mar 22, 2008 | Pioneer GM-6300F Car Audio Amplifier
More bass
Run one set of RCA lines from head unit to amps if you only have one set of pre-outs on the head unit, then at the amps, use an electronic crossover to split between the two amps, and this will also allow you to control what frequencies go to which amps/speakers. You should use one amp for the speakers and the higher power amp for the subwoofer. You should not try to connect both to the subwoofer. Use 4gauge cables if possible. If you have more questions, just ask.
Oct 29, 2007 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
