Question about Dolphin Mini Helicopter Series 3 Channel Indoor Co-Axle Grey
Dolphin helicopter zs-016-h made by zhong sheng hang name is hercules dolphin electric rc helicopter length 74.5cm look for main rotors and inferior rotor and tail rotor
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
How long should charge the battery in my nano hercules helicopter
I re-categorized your post for you. It was posted in the MP3 player section. It should take approximately 20 minutes to charge, but it could take longer depending on the wall adapter and the cable you're using to charge it. Also, if you plug it into a computer it will take longer as it puts out less power.
Dec 26, 2015 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
Helicopter swerves right at speed
Hang it from a sting attached to the rotor shaft and see if it hangs level. It sounds to me like it is off balance.
Mar 07, 2014 | WL Toys WL V912 MAX 4CH FP RC Helicopter...
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
My back rotor for my Hercules Helicopter's wont work need help!
Motor failure. They don't last long. Look on fleabay for a cheap replacement. If you have a soldering iron, you can unsolder them both and insert a 3v watch battery. If it runs, then it could be the control board or else the transmitter stick control.
Jun 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
Bought Nano Hercules RC Helicopter. Flew it once and now lower rotor won't turn. Tried to call World Tech
I, too, have the Nano RC heli. Mine spins and spins faster if I try and take off.
Yours is a relatively easy fix. There are SCREWS under the rotor blades on the bottom. Tighten those.
Dec 28, 2012 | Toys
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
Tail rotar
Yes - it matters for any heli.
The main rotor creates drag which makes the heli want to spin - the tail rotor pulls the heli in the opposite direction to compensate and keep it steady.
Look at the angle of the main rotor in regard to the direction it turns - you'll see how it 'pulls' upward. The tail rotor will need to 'pull' sideways, according to whichever direction the tail rotor is spinning.
I'm assuming you're reattaching a tail rotor or rewiring a motor?
Nov 19, 2008 | RC Airwolf Rc Electric Helicopter Body...
Dolphin Mini Helicopter Series  3 Channel Indoor Co-Axle Grey Logo
1,151 people viewed this question
Top Dolphin Toys Experts
Are you a Dolphin Toy Expert? Answer questions, earn points and help others
