Question about Bodycraft TR1180 Light Treadmill
Motor immediately shuts-down upon start-up - Bodycraft TR1180 Light Treadmill
    New Friend:
  • 69 Answers
You can get new brushes here
http://www.partsfortreadmill.com/parts-for-treadmill/treadmill-motor-replacement/treadmill-motor-brushes-20x9x22-h-mm.html
and you can check here for treadmill help in general
http://www.treadmillsrepair.co.uk/
http://www.partsfortreadmill.com/repair/repair.htm
Posted on Dec 08, 2014
  • 79 Answers
Check the brushes, if the machine turns on normal but the engine does not work can be a problem with the brushes, check the connections or wires that go to the motor drive card. Also check the speed sensor is often a magnet
Posted on Feb 06, 2010
Ssangyong Kyron 2007 shuts down when driving
run fault codes and look for a problem with the TCM ( possible reading and engine over speed which shuts the engine down)and it should re-engage gears immediately upon reselection
Feb 09, 2014 | 2007 SsangYong Kyron 2.0D
Air Compressor trips breaker under load. If I remove the belt the motor runs fine, spins freely as does the compressor pump. With the tank pressure empty, the compressor starts and runs fine. When it...
Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
Oct 22, 2013 | Campbell Hausfeld VT6290 2.0 HP 20 Gallon...
My Husky Pressure Washer bogs the motor down immediately upon start.
Rebuilding the pump is not easy. Did you use the right seal drivers? Lube the seals when you installed them? Use a torque wrench? But a valve in backwards?
May 04, 2013 | Garden
Mac g5 wont start led light blinks once every 7 sec
Hold down the power button until the computer shuts off. The press the button to restart and see what happens. There are several different ways to startup. immediately upon hearing the boot tone, press and hold the shift key to boot in safemode. If this fails as well, then you will need to boot with the install CD. This is done by immediately pressing holding the C key upon powerup
Jun 27, 2012 | Apple Power Mac G5 Desktop
My dryer starts the first time with no problem, but after about an hour it starts to make a kind of buzzing sound. If I don't shut it off at this point it shuts itself off after another minute or two....
You are absolutely correct that the motor is the problem and needs to be replaced. The motor is overheating and its thermal overload protector trips off causing the dryer to shut down. Thermal overload protector resets and allows the motor to run again only when it has cooled down. It is the reason why the dryer is not turning on immediately after it shuts off. Replacing the motor will definitely solve the problem.
Aug 11, 2010 | Maytag Dryers
Craftsman 6hp 150psi 30gal won't keep running
It sounds like the internal circuit breaker in the motor is heating up and then the breaker trips to shut down the motor. This is the protection so you don't have a fire if the motor burns up. The smell you have is the coils in the motor. Sorry to say that you will need a new motor for this unit. I hope this helps out.
Jan 17, 2009 | Air Tools & Compressors
Travelmate 290 starts then shuts down
please re install the recovery software.
Dec 10, 2008 | Acer TravelMate 290 Notebook
Bodycraft TR1180 Light Treadmill Logo
349 people viewed this question
Top Bodycraft Exercise & Fitness Experts
Howard
Howard
Jay Plesset
Bill Boyd
Are you a Bodycraft Exercise and Fitnes Expert? Answer questions, earn points and help others
