Question about AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
I am looking for this motor or an eqivalent:mod.# k48n2n113a1, rpm 3450, 2hp.,230v, 1081 design ST 1202,FR-46j,enclosure- Dp. rot. cwle, code h
  • 3,600 Answers
Copeland a/c replacement motor serial No. 07FR3A171L
fixya doesnt sell products -do online search for replacement parts in youir area or for purchase
Aug 26, 2017 | Heating & Cooling
How to connect a motor
It should be either on the nameplate or junction box cover.
Apr 24, 2014 | AO Smith Evaporative Cooler Motor 2 hp...
Emerson 1081
The 1081 is the designation for a motor that can run continuously (all pool pump motors have that). The motors are generally not cost effective to be repaired.
But, if you are looking for is the manual for the PUMP, see if you can see any identification on the part of the pump that the motor is attached to. Then it should be easy to find.
Oct 16, 2013 | Pool & Spa
How do you wire a type b 3450 rpm mod.c48k2pa105c5 motor to electrical box
two red wires means 220 volt those are both hot green is ground
red to L1 2nd red to L2 then green to ground ( to case) make sure on side of motor it is wired for 220 volt
Apr 03, 2013 | AO Smith A O Smith Motors Century 1hp 115v...
I need wiring diagram for Gould Century Pump motor 1081 Part # 8-142776-20 1HP 230v/120v
www.bestbuypoolsupply.com/media/motormanual.pdf
This manual has the wiring diagrams both hi and lo voltage for
part # 8- 142776 -20 gould century 1081m 1 hp , pool pump motor 230/115 volts.... plus several similar motors
May 25, 2012 | Plumbing
My motor is:Part.Num.6-348524-04,FR:F215T 7.5HP 230volts 1P;What means Type CP and Code H ?
In the US, the motor industry has worked on a standardized basis for labeling the potential performance/ characteristics of a motor. I have noticed at our repair business that Imported motors, depending on country of origin, have many different designations. For example, the stock number that you list includes a (fr:) reference. In the US, this would be listed as (FR frame, or frame type) which refers to various external components of the motor relating to mounting etc.. Code could/usually refers to insulation class of windings relating to highest temperature the motor can endure. Codes for temp are (B,F,H) and others. (Types) of motors usually indicate/ relate to torque-speed curves, rpm, capacitor start, capacitor start and capacitor run etc. Unfortunately I could not find reference to your motor, however, you can probably guess at the capacity of your motor by the application. ex. motor to turn a large fan vs a motor with high start torque requirements for air compressor (inforation needed if you were going to replace a burned motor). More information can be found by reading about "NEMA and IEC standards for motors" Good luck.
Standard for Motors
torque-speed curves for motors with NEMA Design A, B, C, and D characteristics.
Mar 25, 2011 | Air Tools & Compressors
I am trying to redeem an itunes card on www.itunes.com but it keeps coming up an error code 1202, how do i get past this?
TRY COPYTRANS MANAGER ITS EASY AND BETTER THAN ITUNES
http://fr.copytrans.net/copytrans.php
DON'T FORGET TO RATE
Jul 04, 2010 | Apple iTunes
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
119 people viewed this question
Top AO Smith Plumbing Experts
Lawrence Oravetz
Boyet Soriano
Boyet Soriano
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
